SRP547W IVR Command Set
Gary Schlender
Can someone point me to where the IVR command set is documented for the SRP500 series routers, specifically the SRP547W.
What entries areall valid after the handset **** access code is provided from the attached handset?
Thanks!
-g
Hello Mr Shlender,
Let me send you the documnetation that you are looking for.
Please check the page 152 of the next manual.
http://www.cisco.com/en/US/docs/voice_ip_comm/unified_communications/srp540_series/administration/srp500_AG_2567701.pdf
If this answer was satisfactory for you, please mark the question as Answered.
Thank you
