Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1143
saladinit
Beginner
SRP547W multi Static Public ip
Peace be upon you and Allah's mercy
Hi ,,
my Networks contain three devices (BPX, DVR, PC) need to fixed IP, do you router supports the Cisco SRP547W  Static Public ip.
1 REPLY 1
Andrew Hickman
I'm not sure that I follow your question completely, but the SRP547 should support the scenario you describe.
Use NAT port forwarding or Software DMZ features to allow remote devices access to your internal hosts.
It is not possible to configure multiple public IP address on the WAN interface, but these may be mapped using Software DMZ.
Hope that helps,
Andy
