06-11-2021 12:13 AM
Hello Team:
I have Cisco RV34W router and confgured SSL VPN and both the link are static but connecting using PPPOE mode.
Weekly once I face a problem VPN disconnection for 30 minutes.
Kindly help me out and any failover for VPN connection, so employee will try both IPs.
Santhosh
06-11-2021 02:35 AM
- Check the logs when this happens, or better, use a syslog-server to capture logging on a continuous basis.
M.
06-16-2021 09:14 PM
Sure I will Check, Thanks
06-16-2021 09:19 PM
log_sslvpnac: facility=SslVpn;msg=ERROR sslserver.c.2370[6B2FF470] connection_thread: Error accepting SSL connection;
2021-06-17T09:17:20+05:30 <error>log_sslvpnac: facility=SslVpn;msg=ERROR sslserver.c.3146[6B2FF470] nonblocking_ssl_accept: Peer closed connection during SSL handshake,status:0;
nonblocking_ssl_accept: Unexpected error during SSL handshake,status:-1;
nonblocking_ssl_write: Inactive sslserver connection context 0x00198D68;
2021-06-17T00:11:22+05:30 <error>log_sslvpnac: Last message 'facility=SslVpn;msg=' repeated 3 times, supressed by syslog-ng on router354002
2021-06-17T00:11:22+05:30 <error>log_sslvpnac: facility=SslVpn;msg=ERROR sslserver.c.3335[75785470] nonblocking_ssl_write: Inactive sslserver connection context 0x0019AD70;
2021-06-17T00:11:22+05:30 <error>log_sslvpnac: facility=SslVpn;msg=ERROR sslserver.c.3335[75785470] nonblocking_ssl_write: Inactive sslserver connection context 0x0019B540;
2021-06-17T00:11:22+05:30 <error>log_sslvpnac: Last message 'facility=SslVpn;msg=' repeated 2 times, supressed by syslog-ng on router354002
2021-06-17T00:11:22+05:30 <error>log_sslvpnac: Last message 'facility=SslVpn;msg=' repeated 1 times, supressed by syslog-ng on router354002
06-16-2021 11:49 PM
- Make sure to use the latest firmware on the RV34W
M.
