Static DHCP issues for RV130 under v1.0.3.16
jsnyder
Beginner
Beginner
When I upgraded my 'RV130' the FW version 1.0.3.16 I was no longer able to view/set Static DHCP in the LAN settings.  I reverted back to version 1.0.2.7 and it worked again.  Anyone else have issues making Static DHCP settings under version 1.0.3.16 for the RV130?
etihaenni
Beginner
Beginner
I have the same issue. I just upgrade the firmware today and now the Static DHCP entries disappear and I'm not able to add rows. I didn't try yet to roll-back the firmware to the previous version.
Samir Darji
Contributor
Contributor
I believe there's a similar issue on one of the other rv series (maybe even this same model).
But I think you've found the fix--just don't upgrade the firmware. Firmwares should be treated like 'feature sets'. If you need DHCP reservation, 1.0.3.16 isn't your firmware.
And this isn't just Cisco--all the smb routers out there are like this.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
Recognize Your Peers
