Static Routing issue
djb031560
I am working with a vendor that initiates a VPN tunnel into my 1800 series router and then sends port specific data to an app located on the LAN. This vendor uses one of my public IP's from their host throught the tunnel. I then use a static map from that IP redirecfted to the private IP on my App server. My app shows the data received but then fails at acknowlegment back to the vendor through the tunnel. I'm not sure why since my router logs sh no error and my app log shows a Asyncronous error 10054, meaning it can't find the target. The vendor sees the data sent and connection open then nothing comes back and the connection immediately closes. I've attached my running config with the IP's changed to protect the innocent.
Dennis
0 Replies 0
