09-06-2012 12:06 PM
I upgrade firmware from 1.0.3.5 to 1.0.4.17 and from this time I can't connect to any site time from to time. I have simple DHCP WAN connection between my provider and the router, my computer connects to router by wire (only Cisco SG 100D-08 stands between them). When I can't access sites I can access my router and the router needs much more time to answer to me via http. I don't use any vlans or internet access to my computer or router.
I have no idea how to find the problem with router. Maybe your questions can give me the way to fix the problem.
09-06-2012 04:42 PM
What router are you referring to? Also, what make and model modem? Are you on DSL, cable, T1?
09-10-2012 07:55 PM
Excuse me. The router is Cisco RV220W. I am on cable connection and I don't have any modem between router and provider. I receive IP from provider via DHCP.
