Trying to access LAN resources through WRVS4400n
ITeamPaul
I am connected with qvpn, I can log in to the router bios remotely, but when I try to map the network drive from my remote location it does not work.
I can detect the machine on the network, but it will not go further and tells me that "said IP was found but could not locate G". Does this mean it is behind a firewall on server side and that I need to create a rule to allow the incoming traffic? Or could it be something else.
rmanthey
Level 4
Level 4
hello Paul,
Yes it sounds like the OS's firewall is blocking file sharing to other subnets than its own.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
