Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
126
Highlighted
Unable to access RV042 after firmware upgrade
After upgrading the firmware of my RV042 router to latest version RV0XX_v4.2.3.14_20200528-code.bin from version 2.2 it's not working. After the upgrade I was not able to access the router using the web interface, then i did a reset, but still not able to reach (now with the standard 192.168.1.1 addresses). It also not replying to ping.
Any suggestions?
2 REPLIES 2
Highlighted
Beginner
Re: Unable to access RV042 after firmware upgrade
We have quite a few of these in service and keep the firmware up to date - so lots of interaction with them.
Just a little experimentation might best help with this.
First, be willing to use a number of browsers such as Internet Explorer, Google Chrome and Firefox.  I've not tried the *new* Edge but it's based on Google Chrome I understand.  And, watch out for cached pages.  If you get a failure once, the browser may decide to repeat the failure page instead of getting a fresh one.  Consider flushing the cache.
Next, the addressing can make the difference:
Things to try:
combinations of
https:// << this one most likely
http://
ports 80, 443, 8008,8009,8443
So, you might try this:
http://[ipaddress]:8008
and so forth.
Let us know!
Highlighted
What is the DIAG LED status showing? Please check whether the NIC connected to RV042 LAN is getting any DHCP IP or not first. In case NIC is showing APIPA IP then you may check once by assigning a static IP on the NIC connected to the RV042 Router LAN port. Assign a static IP (apart from 192.168.1.1) on the NIC from the pool 192.168.1.x /24 and then try to ping 192.168.1.1.
And in case NIC is showing any other DHCP IP then please try to access the RV042 once using the gateway address. Please disable any other NIC in your system along with firewall during troubleshooting.
You may open a service request following the below mentioned link to troubleshoot further…
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
