05-03-2011 10:10 AM
I can not connect to domain name ( www.mydomain.com\mail). From outside LAN it is with no problems but inside LAN I must log in with internal IP.
I have a Synology NAS with mailserver and photo station there and I have a port forward setting. Everything else is OK.
Can somebody help me, please?
Kaudik
05-03-2011 01:49 PM
Do you have a DNS server for your network?
If you do, you will have to configure a DNS zone or add a DNS record for your mail server. If you do not have a local DNS server, then the problem is similar to the SA500 routers where DNS hairpinning was or maybe still is a problem.
In my opinion, this is really not a problem and if it were my router I would prefer it not be able to resolve names in that manner. If I wanted to get to https://webmail.fancyrouter.net while I was working in my office at FancyRouter I would want to keep all my internal traffic (LAN) local. There is no reason to use WAN bandwidth for something local. So I would have a DNS server locally and I would create a DNS entry like this:
Domain: fancyrouter.net
Mail Server:
A record
gspfncymail (Hostname)
gspfncymail.fancyrouter.net (FQDN)
IP: 10.10.20.250 /16
NEW PART:
CNAME
mydomain.com
*** This is an ALIAS for your mail server A record ***
Now this may not work as above because your email application is actually a WWW record. So, you may have to JUST create a WWW record and point it to the mail server.
More information on how you are resolving DNS and are issuing local addressing would be helpful
05-15-2011 07:29 AM
Thank You for your quick reply.
No, I don't have dns server ina my LAN. I was finding this problem on this forum and here is more users with same problem and Cisco technicians don't answer.
I Think to change hosts file in local pc (3 notebooks), but if I connect from outside to my mailserver, it will be not work.
So I don't know what to do with it.
Thank You.
05-17-2011 03:22 PM
You have an internal email server but you do not have an internal DNS server? What are you using as an email solution?
I have to aggree that creating static entries in host files are not a good idea. So let's just say there is nothing wrong with the router and we just need to make a configuration change. You must have a DHCP server on your network correct? If you so, is it configured to hand out a search domain, like 'mycompany.local'? Also, do you have a file server in your company and if you so how are you accessing your shares? Are you using a hostname or an IP address?
05-25-2011 12:06 AM
I use Synology NAS as email server (Postfix) and I haven't DNS server. Cisco works like a gateway and DNS server. But there is no way to set DNS record. I have no domain server in my lan. I have only registered "mydomain.com" and MX records for my IP.
If I had Dlink router and I try to connect to my NAS, I connect to www.mydomain.com:port and with Cisco it doesn't work.
I have one subnet and I can connect to other PCs with a PCname, it works fine. And my fileserver is Synology NAS.
