08-21-2018 02:08 PM
I have purchased an RV340 to replace our RV016 and am hoping that there is a way to migrate the settings from the old router to the new so I don't have to do all the setup from scratch. Can I just upload a saved config file from the old router to the new? Or, if not, is there another less laborious method than doing it all page by page?
Thanks for any help you can offer. I'm definitely a beginner at this!
Solved! Go to Solution.
08-24-2018 04:25 AM
Unfortunately, it is not possible to download the configuration file from the RV016 and upload it on the RV340 - they are running totally different firmware.
08-24-2018 04:25 AM
