08-27-2020 11:33 AM
I'm trying to setup a VLAN that has more IP addresess available via DHCP.
When I try to change it to a 255.255.254.0 (23), it will not save. I've not done this before anywhere so maybe not an true option, but I've read discussions on the process.
G.T.
Solved! Go to Solution.
08-31-2020 11:02 AM
It is possible to assign the /23 IP pool on the VLAN interface and enable the DHCP server. Please try different browser and check once. Please refer the attached screenshot for VLAN115.
08-28-2020 01:27 AM
- Do you get some sort of error , if so which one ?
M.
08-28-2020 10:21 AM
No errors, the fields turn Red, indicating a non valid value. So that is not the way to do it if there is a way.
08-31-2020 11:02 AM
09-01-2020 11:51 AM
Sujoy,
You are correct, I was trying to change the subnet on VLAN1, and it can not be changed it seems, however the other VLANS we have can.
I appreciate you showing me the screenshot, it made me check the other VLANS.
