01-08-2015 09:02 AM
Hello I Try to make a VPN site to Site
I have a VPN connexion but , it is impossible to ping an ip address only the gate from the other site (192.168.1.77 from the network 1.18.0.0) or (1.18.0.77 from the network 192.168.1.0)
Thank you very much for your help
I use this setting for the PC
This is the configuration for the router A
This is the configuration for the router B
01-08-2015 09:32 AM
Hi Muller,
All configuration it looks fine and also you confirmed that you can ping the remote routers IP so the VPN is UP and there is a data through the VPN.
just for to confirm On the PC where connected to Network 192.168.1.0/24 he has Gateway 192.168.1.77 ?
Can you confirm please if you disable firewall on both PC's ?
Please share your result after your test
Please rate this post or marked as answered to help other Cisco customers
Mehdi
01-08-2015 09:45 AM
Hello :-)
On each PC the firewall is down and on cisco
01-08-2015 11:33 AM
You might want to try using private IP addressing on the LAN behind router B. In spite of the local/remote interesting traffic selector in the VPN policy settings the router might still be trying to send the return traffic out to the internet rather than across the tunnel.
