Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1721
mderriennic
Beginner
Wake On Lan - WOL through RVL200
Does anyone have a clue to have WOL / Wake On Lan working through a Linksys RVL200 SSL router.
The trick on Linksys router disabling java/javascript doesn't work !!
Event when the SSL VPN is on, using a WOL tool on a remote computer doesn't work :(
Thanks !
1 REPLY 1
Ray Long
Beginner
You may need to just forward a port through the router. A typical port used for wake on lan is UDP 9.
Try this google search for some clues http://www.google.com/search?hl=en&rls=com.microsoft%3Aen-us&q=wake+on+lan+through+the+internet&aq=6&oq=wake+on+lan+through+&aqi=g7
