I am having an issue with a WAP4410N repeating WPA2 Personal mixed signal from a AP Setup in a RV120V device. I am able to connect to the 120V AP without an issue. I set the WAP4410N to repeat that signal. No problem. However when I try to connect via the WAP4410N it keeps telling me the secuirty key is invalid. I have verfied that it is. It is the same password used to connect to the RV120V. Can anyone tell me how to coorectly setup the WAP4410N to repeat the signal and allow users to connect? Thanks for you time in advance.
