12-20-2013 01:57 PM
Hi tech,
I have just bought Prixma MG5420 and connected it to CIsco RV220w. The printer is getting the ip address and it is being shown on the staus->LAN interface of the router. But when I try to search for the printer over the same network from a pc having windows 7, its not able to find it.
Thanks.
Solved! Go to Solution.
12-20-2013 04:59 PM
Zaki,
Go to Wireless-> Basic Settings and disable Wireless Isolation within SSID for the SSID that the printer is connected to.
- Marty
12-20-2013 04:59 PM
Zaki,
- Marty
12-23-2013 11:00 AM
Thanks Marty..it did work out...
