WRVS4400N port forwarding unresponsive
bcmitsupport
Router: WRVS4400N
Firmware: 2.0.2.1
Background:
Port forwarding external port 1234 to internal port 123 on a NAS appliance (ip 192.168.1.111)
Successfully accessed NAS like this:
https://11.22.33.44:1234/MyShare
Everything was working perfectly for several weeks
Last week I changed the subnet to 172.17.888.x
Problem:
Everything back to normal on the LAN except that port forwarding to the NAS no longer works.
Gerfingerpoken:
I opened another port (1235) and forwarded that to the NAS (in addition to the original port).  No success.
I tried a port scanner. The port scanner reported that port 1234 was open on the router, but didn't mention 1235.
I repeated with yet another port.  Same result: only port 1234 is reported open by the port scanner.
Software rebooted the router, same result
Hard reset (button) the router, still no change.
QUESTIONS:
1.  How can I test if the router is actually forwarding new ports? (software tool?)
2.  Any thoughts or suggestions?
bcmitsupport
Update.
Port forwarding was working, but the recipient device (NAS) was not accepting connections due to a misconfigured security certificate. It was necessary to regenerate the security certificate on the NAS device and all started working.
HOWEVER, it would be very nice to know if port forwarding was actually working.  Knowing that would have eliminated half the possibilities and greatly simplified troubleshooting.
