WRVS4400N + QuickVPN+win7/8 64bit
itlahituki
Two weeks ago i got this working and now test again with two differend PC and it doesnt work. (one win7 64bit and one win8 64bit) I try it with XP and it works perfectly. I allready try to create ICMP FW rules. Install new fimware to router, Run quickvn installation in compatibility mode and nothing helps.
Checked all settings. I cannot understand why there is no fix/update for client! this is very annoying. i think we have to change VPN.
itlahituki
the remote gateway is not responding Do you want to wait.
If same network 192.168.1.x for client machine it works with win7 or 8. if i try with 3g it gives that remote gateway error.
With XP it works fine
