11-27-2012 03:43 AM
I couldn’t connect to my ISP with PPPoE, below is the log of connection attempts. Is there any solution of this problem?
Here is a portion of log during connection attemts
All Log
Type:
Jan 1 03:05:00 - Plugin pppoe loaded.
Jan 1 03:05:00 - PPPoE Plugin Initialized
Jan 1 03:05:00 - Plugin pppoe called.
Jan 1 03:05:00 - pppd 2.4.1 started by root, uid 0
Jan 1 03:05:00 - Sending PADI
Jan 1 03:05:00 - HOST_UNIQ successful match
Jan 1 03:05:00 - Unexpected packet: Ether addr: 00:30:88:1c:48:5b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:05:00 - Unexpected packet: Ether addr: 00:30:88:1c:47:df (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:05:00 - Unexpected packet: Ether addr: 00:30:88:1c:47:dc (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:05:00 - Unexpected packet: Ether addr: 00:30:88:16:de:98 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:05:00 - Unexpected packet: Ether addr: 00:30:88:16:de:95 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:05:00 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x42618
Jan 1 03:05:00 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 03:05:00 - Doing disconnect
Jan 1 03:05:00 - Exit.
Jan 1 03:05:20 - Plugin pppoe loaded.
Jan 1 03:05:20 - PPPoE Plugin Initialized
Jan 1 03:05:20 - Plugin pppoe called.
Jan 1 03:05:20 - pppd 2.4.1 started by root, uid 0
Jan 1 03:05:20 - Sending PADI
Jan 1 03:05:40 - Plugin pppoe loaded.
Jan 1 03:05:40 - PPPoE Plugin Initialized
Jan 1 03:05:40 - Plugin pppoe called.
Jan 1 03:05:40 - pppd 2.4.1 started by root, uid 0
Jan 1 03:05:40 - Sending PADI
Jan 1 03:06:00 - Plugin pppoe loaded.
Jan 1 03:06:00 - PPPoE Plugin Initialized
Jan 1 03:06:00 - Plugin pppoe called.
Jan 1 03:06:00 - pppd 2.4.1 started by root, uid 0
Jan 1 03:06:00 - Sending PADI
Jan 1 03:06:20 - Plugin pppoe loaded.
Jan 1 03:06:20 - PPPoE Plugin Initialized
Jan 1 03:06:20 - Plugin pppoe called.
Jan 1 03:06:20 - pppd 2.4.1 started by root, uid 0
Jan 1 03:06:20 - Sending PADI
Jan 1 03:06:22 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x42618
Jan 1 03:06:22 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 03:06:22 - Doing disconnect
Jan 1 03:06:22 - Exit.
Jan 1 03:06:40 - Plugin pppoe loaded.
Jan 1 03:06:40 - PPPoE Plugin Initialized
Jan 1 03:06:40 - Plugin pppoe called.
Jan 1 03:06:40 - pppd 2.4.1 started by root, uid 0
Jan 1 03:06:40 - Sending PADI
Jan 1 03:06:42 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x42618
Jan 1 03:06:42 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 03:06:42 - Doing disconnect
Jan 1 03:06:42 - Exit.
Jan 1 03:07:00 - Plugin pppoe loaded.
Jan 1 03:07:00 - PPPoE Plugin Initialized
Jan 1 03:07:00 - Plugin pppoe called.
Jan 1 03:07:00 - pppd 2.4.1 started by root, uid 0
Jan 1 03:07:00 - Sending PADI
Jan 1 03:07:00 - HOST_UNIQ successful match
Jan 1 03:07:00 - Unexpected packet: Ether addr: 00:30:88:16:de:98 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:07:00 - Unexpected packet: Ether addr: 00:30:88:16:de:95 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:07:00 - Unexpected packet: Ether addr: 00:30:88:1a:29:9b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:07:01 - Unexpected packet: Ether addr: 00:30:88:16:de:95 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:07:01 - HOST_UNIQ successful match
Jan 1 03:07:01 - Unexpected packet: Ether addr: 00:30:88:1a:29:9b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:07:01 - Unexpected packet: Ether addr: 00:30:88:1a:29:98 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:07:01 - Unexpected packet: Ether addr: 00:30:88:1c:48:3b (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
Jan 1 03:07:01 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x42618
Jan 1 03:07:01 - Couldn't get channel number: Transport endpoint is not connected
Jan 1 03:07:01 - Doing disconnect
Jan 1 03:07:01 - Exit.
Jan 1 03:07:01 - Unexpected packet: Ether addr: 00:30:88:16:de:98 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x001b (PADO) PPPoE tag: type=0103 length=0004 (Host Uniq) data (bin): 18 26 04 00 PPPoE tag: type=0102 length=000b (AC Name) da
12-11-2013 01:37 AM
DAMN i have the same Problem and still no solution
12-11-2013 11:09 AM
NA,
Set up a PC for PPPoE and connect to the modem. Make sure you have internet access. Then use the MAC address clone feature in the WRVS4400N to clone the PCs MAC to the router. Try to connect the router to the modem again. This usually resolves this type of issue.
- Marty
12-12-2013 01:12 AM
can you explain why i have to do that ?
I have a VDSL modem in pass trough mode and behind the wrsv4400n .
If i clona a PC's MAC to the router, i will get problems later if the router and the pc have the same MAC.
12-12-2013 08:13 AM
Sometimes modems refuse the connection to routers. If they will connect to another device, such as a PC, then you can clone the MAC of that PC to the router to trick the modem into 'thinking' that the PC is connecting. This is usually done on a DHCP connection, although I have seen it work with PPPoE as well.
You should never see any issue with the PC and router having the same MAC because they are on completely different networks. The router is on the ISP network (WAN) and the PC is on the LAN network of the router. We use this trick all the time when we can't get a modem to play nice with a router. If there was danger of conflict the functionality would not be in every consumer and SMB router available. (That I am aware of) I will not guarantee that it will work but it is certainly worth a try.
I have seen cases where a certain brand/model of modem will not under any circumstances work with the router. In that case you can either replace the modem or replace the router.
- Marty
