WRVS4400N v2 and IPv6 traffic bridge between WIFI and ethernet
milanroubal
I have problem with IPv6 on this router. I have on my ethernet linux box, that is responsible for IPv6. This box is configured as IPv6 gateway from my network and it also sends RA to the network. All devices on ethernet network can work on IPv6 without problem.
Clients, that are connected to WiFi, they just receive the RA from this box -> this packet is sended over WRVS4400N to the wifi network. But all other traffic do not pass the WRVS4400N, so the wifi client is not able to ping the IPv6 gateway. There is no problem on IPv4, there the wifi client is able to communicate with any ethernet device.
I have tested WRVS4400N setting "ipv4 only". If I switch on "ipv4 and ipv6", than all devices will get some additional IPv6 adresses and the communication from WiFi client to IPv6 router is not working again.
How to configure the WRVS4400N to bridge all IPv6 traffic between WiFi and ethernet?
  Thank you
milanroubal
Nobody here who has working IPv6?
i've tried to get it working, but got no answer in this forum. it seems that they try to frustrate you enough to get another device and hope that it will be another cisco ...
https://supportforums.cisco.com/thread/2125770
https://supportforums.cisco.com/thread/2127264
