Youtube video streaming limiting on cisco 881 using NBAR2 and ZBF
shehanfernando
I'm trying to limit (qos) Youtube video bandwidth using cisco NBAR2 and ZBF . Blocking the youtube is working fine but when try to police the traffic rate it does not work at all . Can somebody help me to fix this ? Are there any way to achieve this video QoS on ZBF ?  I just want to limit bandwidth of youtube video
class-map type inspect match-all LIMIT_YOUTUBE
      match access-group name ZEZO_DOWN_USERS
      match protocol youtube
policy-map type inspect INSIDE_TO_OUTSIDE_POLICY
    class type inspect LIMIT_YOUTUBE
        inspect
        police rate 8000 burst 1000
    class type inspect DEFAULT_POLICY
        inspect
        class class-default
        drop
Philip D'Ath
Your config reads like you are policing traffic going from the inside to the outside of your device.
You need to do this in the opposite direction - the downloads, instead of limiting the uploads.
I have some doubts about incoming traffic filtering.
1) First scenario
If policy is put like below, no incoming traffic is filter because of inspect command on "DEFAULT_POLICY_OUT" class
    class type inspect DEFAULT_POLICY_OUT
       inspect
    class class-default
       drop
policy-map type inspect OUTSIDE_TO_INSIDE_POLICY
          drop
       class class-default
          drop
2) Second scenario
       class type inspect PASS_YOUTUBE
           pass
           pass
       class class-default
           drop
            drop
       class type inspect DEFAULT_POLICY_IN
             pass
       class class-default
             drop
in this policy, i can filter the incoming traffic (dropping youtube traffic is working fine) but can't police the incoming traffic because police command could not use with pass command.
I alter the above police little bit and try following as well. but it does not work somehow. Can you make any suggestion ??
   inspect
     inspect
