Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
119
Highlighted
Beginner
Client to Site VP
Good day Community hope you are doing well.
I have the following question for you
I need to establish some ipsec sessions for a small business, my question is the following
if I do not wish to enable Cisco Anyconnect client, can I use Windows default client as well as other VPN clients
without needing additional licenses, also could you confirm that the device rv345p supports up to 50 Ipsec sessions without needing additional licenses?
best regards
1 REPLY 1
Highlighted
Re: Client to Site VP
Please note IPSec on RV345 P supports 50 simultaneous connections (any combination of remote access and site-to-site), up to 650 Mbps throughput. Please refer below link and check for IPSec in Product Specifications for the same.
https://www.cisco.com/c/en/us/products/collateral/routers/small-business-rv-series-routers/datasheet-c78-742350.html
In case you want to use windows default client for VPN, you can use PPTP and Layer 2 Tunneling Protocol (L2TP) over IPsec. Point-to-Point Tunneling Protocol (PPTP) supports 25 connections, up to 100 Mbps throughput.
Please refer to below link for detailed information about PPTP and Layer 2 Tunneling Protocol (L2TP) over IPSec.
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV340/Administration/EN/b_RV340x_AG.pdf
Please refer below link to configure Layer 2 Transport Protocol (L2TP) Server Settings on an RV34x Series Router.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5472-configure-layer-2-transport-protocol-l2tp-server-settings-on.html
You can also use 3rd party VPN client "Shrew soft" in case you don't want to have an additional license. This works on IPSec.
