My problem is this :
when I activate URL Filtering and Load Balancing, I've got a lot of DNS errors and HTTP access becomes very very slow...
when I disable URL Filtering with Load Balancing active, all works well...
How can I do to make URL Filtering and Load Balancing working at the same time ?
Hi Thierry,
Can you please let me know which firmware version are you using on SA500? The latest firmware is 2.1.51 and can be downloaded from www.cisco.com
Also could you please provide us dbglogs when the issue occurs. Please change / remove all passwords before providing the dbglogs. To get dbglogs, log into SA500 web UI and in the URL type the following:
https://IP_address_of_SA500/scgi-bin/dbglog.cgi
Nitin
