Get the latest Cisco news in this December issue of the Cisco Small Business Monthly Newsletter
1111
Beginner
How to create & assign VLAN to specific ports
In our ISA550W, creating VLAN for different subnets and assigning them to specific ports is a piece of cake and self explanitory.
However on an SG300-10MP, I'm totally lost lol. I simply want to make ports 7 & 8 set to a .10 subnet instead of a .6 like the rest of the switch. I need these ports to be totally independent from the rest and not communicate with the others at all.
How do I do this?
Thanks!
1 ACCEPTED SOLUTION
Beginner
Re: How to create & assign VLAN to specific ports
Hi Alex,
Under VLAN Management go to interface settings.  Change the interfaces you are using to access ports by choosing the desired port and clicking edit.
Once they are access ports go back to the Port to VLAN page and assign the desired port as a untagged in that interface.
This should be all you need, let me know if you have any further questions.
-Trent Good
** Please rate useful posts! **
-Trent Good ** Please rate useful posts! **
12 REPLIES 12
Highlighted
Beginner
Hello Alex,
I found some articles relating to the SG300 series devices. They help explain how to assign ports to different VLANs. I hope that they can be helpful to you in your configuration.
Configuration of Port to VLAN on 200/300 Series Manged Switches
Configuration of VLAN Membership of an Interface on the 200/300 Series Managed Switches
Hope they help,
Andrew Mayfield
Beginner
Andrew,
Thank you, I will read and follow them.
I guess what was throwing me off is that during the creation of the VLANs, you don't identify the subnet in anyway. On the ISA, you specifically would tell it 192.168.10.0 for example. On the SG, it doesn't, just create a VLAN identifier and link it to a port and it doesn't care the subnet.
Thanks!
Alex
Beginner
I'm still not sure what to do on the last portion, the second link.
I add the 10 VLAN I created to the port, and I mark it as tagged. Ok.
But I want to remove the default 1 VLAN from the port because I do NOT want the traffic able to cross from this VLAN and port to any other the other VLANs and ports, and no matter what variations I choose, it won't let me.
Beginner
Hi Alex,
-Trent Good
Beginner
Gotcha, yeah that removed the default VLAN from the Port VLAN Membership page.
1 Final question, I made them untagged as you mentioned, but on the Port VLAN Membership page, should I leave them as tagged?
Beginner
Hi Alex,
The Port VLAN Membership page, vlan to port page, and interface settings page should all reflect the same thing.  It should show something like [vlan id]UP or something like that.
-Trent Good
Beginner
Port VLAN Membership shows TP
Port to VLAN show Tagged
Interface settings shows:
7 GE7General10Admit Tagged OnlyEnabled
Is that correct, or should everything be switched to Untagged?
Thank you VERY much for the help!
Beginner
You want to switch everything to untagged.  Most devices by default will not understand tagging.
-Trent Good
Beginner
Ok, now my settings look like this:
Port VLAN Membership shows UP
Port to VLAN shows Untagged
7 GE7General10Admit Untagged OnlyEnabled
Funny thing tho, when I go into the Port VLAN Membership and edit, it shows as set to Tagged even though the summary shows UP. If I set it to untagged and saved it, it just goes right back to Tagged. Is this normal and OK?
Thanks!
Beginner
Hi Alex,
Change the interface from General to Access.  Then it will for sure only allow 1 Untagged VLAN.
-Trent Good
Beginner
That did it! Thank you!
Beginner
Also, you’ll want to be sure
Also, you’ll want to be sure to secure your VPN authentication beyond just a password using a shared secret between your VPN client and the server. There is a 3rd party integration that will do that.
