Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
921
nielsentonni
Beginner
ISA500 Series - Captive Portal
Is there anyone who have the Captive Portal working properly with a FQDN approved certificate ? I have already installed a approved certifiacte but each time the client is redirected to the Captive Portal default ip address on the ISA router used. Is there any option where it will redirect to a FQDN example the host and domain name of the router - insted of the routers ip adress ?
Tonni
1 REPLY 1
lariasqu
Beginner
Hi Tonni, thank you for using our forum, my name is Luis I am part of the Small business Support community. I apologize for your inconvenience, in this case I found an article and I thought that could be helpful in order to configure your Captive Portal.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3458
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
