in case of having lots of performance issues with my ISA box I usually check the logfiles. I often get "high cpu load" and sometimes the cpu has 100% over minutes. I thing streaming media cases this behaviour, but I am not sure.
does anybody else has this problems too?
Regards Mike
fw: 1.17
app control active
URL filter active
Good morning
Hi Michael, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. You could have performance problems due to the amount of services you have activated, for example if you have enabled the IPS,if you have too many VPN, routes, access-rules and others features enabled it could affect the performance I recommend you disable the features you are not using, you can also perform a factory reset and configure just the necesary features you need. I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it*
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
