Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
1417
Beginner
SA 540 Port Translation Not Working
Geez, I am having all kinds of problems with this SA 540.  I configured a custom firewall rule as seen below.  The intent is to port forward into an internal workstation and translate the port to the standard RDP port of 3389 (second image).  The external client goes to rdp.domain.com:9833 to make the RDP connection.  It worked for a day and then it did not.  I have disabled the rule and re-enabled it, deleted it and recreated it, changed the port and nothing works.  The logs don't even record a hit.
I can't restart the router until after hours, but why would that even be necessary?  How about it Cisco?  Is this a problem with the appliance?  It is running firmware version 2.1.71.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Beginner
It's good to hear that you were able to resolve your port translation issues.
4 REPLIES 4
Frequent Contributor
Re: SA 540 Port Translation Not Working
Anthony,
Everything seems to be set correctly but i have a few questions? First i see you specified external IP address (optional WAN)how is the both wans configured, and do you have SA540 in load balance mode? if so do you have any protocol binding rules enabled? (If so) the computer you're using to connect (RDP) are you binding it out the optional WAN or Dedicated WAN. This could conflict depending on your rules.
Jasbryan
Beginner
Thanks, Jasbryan, for the quick response.  The optional WAN is an active connection using FIOS.  The dedicated WAN is using Road Runner.  The mode is configured for failover with the Road Runner connection in standby.  It just happened that way.  Originally, Road Runner was to be the primary Internet connection, but it did not prove as reliable as FIOS (FIOS is faster, too).
When a user attempts a connection, it is to vpn.domain.com:9833 for example.  I am to configure about six ports in all, so they will translate from 9833 through 9838 to the internal workstations at 3389.  Also, there is a server that is being translated on the traditional RDP port so you have 3389 to 3389 on that one.  The server works fine.  If you look down the list in the below image, you will see Websense.  That works, too.  I am just wondering if the SA 540 is having trouble port translating multiple connections coming in on different remote ports, but going to the same local port even though it is to different computers.  What do you think?  This should not be a problem.  I do this exact thing using other routers.  As a test, I disabled the first RDP rule in the list and there was no change.
This really has me stumped.
If the image is not viewable in this post, save it to your computer and then view it.
Beginner
This issue has been resolved.
The problem was a group policy on Windows workstations the client had not told me about.  It limited remote desktop connections to only requests made on the local subnet.  When the policy was changed to accept all requests for remote desktop connections, the port translation on the firewall worked.
Beginner
