SA520 Content Filtering
deernetwork
Beginner
Beginner
We have a SA520 and want to enable the content filtering
However we found that the user can bypass the URL filter easily if the site provides https service
For example, we want to block facebook, and we have enter facebook in the block list
If the user browse using http://www.facebook.com, it blocks
However when the user using https://www.facebook.com, it works!
Is there any solution to close this backdoor?
6 Replies 6
nmanglik
Currently SA500 only supports content filtering only on port 80.
Nitin.
Is it true SA520 only supports content filtering on port 80?  Has this been fixed?
sorry, maybe I am misunderstanding this issue, but on my 520 https content is also filtered.
firewall -> content filtering -> http port: 80, 443; web components: all ticked.
firewall -> content filtering -> blocked urls: www.facebook.com: website, facebook: URL Keyword
what am I doing wrong ... ? ;-)
kind regards
eckhard
Eckhard,
When the other engineer said the SA500 only filters content on port 80 we can only filter normal unencrypted web traffic. Since https is encrypted the router can't read the content at which the end user is accessing. Since the router can't read this content because it is encrypted then we can't filter any content that uses https or 443 traffic. That being said some people filter at the DNS query as i do. Instead of trying to block at content we can block the DNS query. OpenDns is a good way to accomplish blocking at DNS level.
Just an example if i blocking content for facebook.com
then if i use http://facebook.comthen i should get blocked
if i use https://facebook.com then since the traffic is being encrypted by the end user the router can't read any encrypted content therefore allowing the connection....
hope this explains further.
Jasbryan
Perfect!
That does not make any sense. The url is not encrypted so url filtering should be able to block access to the URL. Real content filtering solutions such as sonicwall, websense etc seem to be able to block https site access. I'm positive this is just a Cisco SA520 short coming in that it only blocks port 80 url access.
Recognize Your Peers
