Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
842
SA520-GW25-BUN3-K9 configure issue
Dear All,
We need to configure on SA520-GW25-BUN3-K9 device
1)Two isp failover configuration
2)band width segrcation configuration on Two isp
3)site to site vpn configuration
4)Globol vpn configuration
5)Gateway level antivirus configuration
configuration required above applications in this device .
1 REPLY 1
rshao
Beginner
The admin guide may have some info to get you started
http://www.cisco.com/en/US/docs/security/multi_function_security/multi_function_security_appliance/sa_500/administration/guide/SA500_AG_OL1911404.pdf
for 1) take a look the "Configuring the Optional WAN" section
for 2) see if this section is close to what you may look for  "Configuring the Protocol Bindings for Load Balancing"
for 3) see Configuring a Site-to-Site VPN Tunnel
not sure 4) but the VPN session may be what you are looking for
for 5) the virut protection is through ProtectLink service.  That is a separate subscription service if you don't purchase "bundle" offering.  The ProtectLink is a cloud-based solution (not a gateway based AV).  It covers web and email applications.
If you still need assistance on those configuraitons, you can also contact Cisco Small Business Support Center.  They may be more effective to assist you on this scope of setup.
Their phone number is:1-866-606-1866.
The following page contains the pertinent contact list.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cheers
Richard
