I've got an SA520, with a few firewall rules set to always log. We also have a bunch of SSL VPN users.
When I go to Status | View All Logs, it's empty. I've also tried every Log Severity, still blank.
Same problem.
Br,
Jouko
Just wondering if logging is enabled ?
If it is, have a quick chat to the Small Business Support Center, so they can help you with the configuration option;
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
hi
all of those are marked for local log.
Still it don't write any log for firewall error/logging.
Other errors are writing and there is lot of those.
Tue Oct 25 14:06:08 2011(GMT +0300) ERROR System sslRemoteMgmtHandler Invoked
Component: SSLVPN
Tue Oct 25 14:06:30 2011(GMT +0300) INFO IPS categories.xml successfully parsed:
Component: IPS
Tue Oct 25 14:06:31 2011(GMT +0300) INFO IPS Categories to signature mappings updated successfully.
Component: IPS
Tue Oct 25 14:06:33 2011(GMT +0300) ERROR System /pfrm2.0/bin/tsumiConfig /tmp/system.db 18 tsumi 1 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:06:37 2011(GMT +0300) ERROR System dbRecordValueGet failed for emergency column
Component: PLATFORM
Tue Oct 25 14:06:37 2011(GMT +0300) ERROR System dbRecordValueGet failed for certData column
Component: PLATFORM
Tue Oct 25 14:06:37 2011(GMT +0300) ERROR System Error in executing DB update handler
Component: PLATFORM
Tue Oct 25 14:06:38 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_FIREWALL, UMI_CMD_DB_UPDATE(4)) failed. table=interVLANRouting row=1
Component: EVTDSPTCH
Tue Oct 25 14:06:39 2011(GMT +0300) ERROR System cslConfigTblHandler: Invalid License Operation
Component: PLATFORM
Tue Oct 25 14:06:39 2011(GMT +0300) ERROR System cslHandleDBUpdate:Error in executing DB update handler
Component: PLATFORM
Tue Oct 25 14:07:53 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 1 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:07:53 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=1
Tue Oct 25 14:07:53 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 2 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:07:53 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=2
Tue Oct 25 14:07:54 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 3 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:07:54 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=3
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 23 bonjourRegisteredServices 3 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=3
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: De-Registering the service
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Service De-Registration Failed
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Error in executing DB update handler
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 3 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 3 failed. status=-1
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 1 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=1
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 4 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=4
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 2 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=2
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 5 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:00 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=5
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:01 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 6 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:01 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=6
Tue Oct 25 14:08:03 2011(GMT +0300) INFO IPS Categories to signature mappings updated successfully.
Component: IPS
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 23 bonjourRegisteredServices 4 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=4
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: De-Registering the service
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Service De-Registration Failed
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Error in executing DB update handler
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 4 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 7 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=7
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 5 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=5
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 8 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=8
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 6 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=6
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 9 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:05 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=9
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 23 bonjourRegisteredServices 7 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=7
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: De-Registering the service
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Service De-Registration Failed
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Error in executing DB update handler
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 7 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 10 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=10
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 8 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=8
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 11 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=11
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 9 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=9
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 12 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=12
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:06 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 10 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 13 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=13
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: De-Registering the service
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Service De-Registration Failed
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Error in executing DB update handler
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 11 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=11
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 14 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=14
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 12 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=12
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 15 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=15
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 13 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 16 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=16
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:07 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 14 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 17 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=17
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: De-Registering the service
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Service De-Registration Failed
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: Error in executing DB update handler
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 15 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=15
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 18 bonjourRegisteredServices 18 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=18
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 16 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed. table=bonjourRegisteredServices row=16
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 17 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: DNSServiceRegister returned err=0
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:08 2011(GMT +0300) ERROR System /pfrm2.0/bin/bonjourConfig /tmp/system.db 9 bonjourRegisteredServices 18 failed. status=-1
Component: PLATFORM
Component: PLATFORM
Tue Oct 25 14:08:15 2011(GMT +0300) ERROR System *******The above log repeated 1 times *******
Component: PLATFORM
Tue Oct 25 14:08:15 2011(GMT +0300) ERROR System /pfrm2.0/bin/vipsecureConfig /tmp/system.db 23 ipAddressTable 2 failed. status=-1
Component: PLATFORM
Tue Oct 25 14:08:28 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: De-Registering the service
Component: PLATFORM
Tue Oct 25 14:08:29 2011(GMT +0300) ERROR System *******The above log repeated 1 times *******
Component: PLATFORM
Tue Oct 25 14:08:29 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: DNSServiceRegister returned err=0
Component: PLATFORM
Tue Oct 25 14:08:30 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: De-Registering the service
Component: PLATFORM
Tue Oct 25 14:08:30 2011(GMT +0300) ERROR System [BONJOUR_ERROR]: DNSServiceRegister returned err=0
Component: PLATFORM
Tue Oct 25 15:04:41 2011(GMT +0300) ERROR System *******The above log repeated 1 times *******
Component: PLATFORM
Tue Oct 25 15:04:41 2011(GMT +0300) ERROR System Locator query FAILED
Component: PLATFORM
Tue Oct 25 15:04:41 2011(GMT +0300) ERROR System ERROR: http operation misc err, Failed to connect to 72.163.4.161: Connection timed out
Component: PLATFORM
Tue Oct 25 15:07:51 2011(GMT +0300) ERROR System Locator query FAILED
Component: PLATFORM
Tue Oct 25 15:07:51 2011(GMT +0300) ERROR System ERROR: http operation misc err, Failed to connect to 72.163.4.161: Connection timed out
Component: PLATFORM
Tue Oct 25 15:11:00 2011(GMT +0300) ERROR System Locator query FAILED
Component: PLATFORM
Tue Oct 25 15:11:00 2011(GMT +0300) ERROR System ERROR: http operation misc err, Failed to connect to 72.163.4.161: Connection timed out
Component: PLATFORM
Bill / Jouko,
What software version of SA500 do you have on the device?
We have checked the Firewall logging functionality in SA500.Please find our observations below:
Steps:
1. Add outbound and inbound firewall rules for PING & FTP service with Logging enabled (Firewall > IPv4 Rules > Edit/Add a Firewall Rule > Log - Always).
2. Under Administration > Logging > Logs facility and Severity, select Logs Severity as 'Warning' and Logs Facility for Local Log select Firewall.
3. Run traffic on Outbound and Inbound firewall rules.
4. To view logs, go to Status > View Logs-> View All logs and select Log Severity as 'Warning' and Facility as 'Firewall' and apply settings.
Observations:
Firewall and firewall rules' related logs will be seen.
If you are still unable to see logs, could you please provide Dbglogs from SA500. To get dbglogs, log in to SA500 web UI and in the URL type
https://IP_address_of_SA500/scgi-bin/dbglog.cgi
Please change or remove passwords from the device as dbglogs will contain passwords. If you are not comfortable posting the logs on the community, then you can send me through private message.
Nitin.
Juoko,
Thank you for providing dbglogs. We looked at the logs and found that the Log Severity was selected as 'Error' which can display only error related logs. In order to see firewall and all other logs in View Logs page, we need to Select Log Severity as Warning/Debugging.
Please follow the below mentioned steps to view Firewall logs:
1. Please change the log Severity from 'Error' to 'Warning'/'Debugging' and Apply settings in Administration>Logging > Log Severity and Facility page.
2. Goto Status>View All Logs>Select Log Severity as 'Warning'/'Debugging' and Log Facility as 'Firewall' and Apply Settings.
You will observe the Firewall logs coming in Status-> View All Logs-> Logs table.
Nitin
Now it works.
Any idea how to get rid of / fix those other errors/ error messages.
Jouko
