Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
1539
Highlighted
SA520 - random reboot - no idea why !
I'm using a SA520 in a hospital in oder to manage VPN and Internet access. They were some troubleshooting with VPN and it seems ok now for 1  month. But for 15 days, the router seems to reboot randomly (2 or 3 time per day) ... why ? i don't know, i had no errors (just one with VPN) ..
The firmware is 2.1.71 (updated for1 month) :  during the night, it seems better ... The CPU is less than 5% used, the Memory is used around 50% .
below the only error that i have (after reboot):
Sat Jan  1 01:05:18 2000(GMT +0100)WARNVPN no phase2 bounded.
Component: VIPSECURE
Sat Jan  1 01:05:19 2000(GMT +0100)WARNVPN no phase2 found for "P_Labo_xxxxx"
Sat Jan  1 01:05:19 2000(GMT +0100)WARNVPN no phase1 found for "Labo_xxxxxxx"
Tue Jan 15 10:57:14 2013(GMT +0100)WARNFIREWALL *******The above log repeated 1 times *******
Component: FIREWALL
Tue Jan 15 11:32:20 2013(GMT +0100)ERRORVPN no iph2 found: ESP xxxxxxxxx>xxxxxxxxx with spi=1995742034(0x76f49b52)
Tue Jan 15 17:39:40 2013(GMT +0100)WARNFIREWALL *******The above log repeated 2 times *******
Component: FIREWALL
How can i do to obtain logs before reboot ?
1 ACCEPTED SOLUTION
Highlighted
Advocate
Hi, yes a default will probably help everything. The release notes indicate the router should be reset on the 2.2.0.7 upgrade. If you call support they will also ask you to do this.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
9 REPLIES 9
Highlighted
Advocate
Hi Ghislain, to get logs before reboot you would need an external syslog server. Just another note, the 2.2.0.7 firmware is now released. You may want to look in to this as well.
Here's the firmware link
http://software.cisco.com/download/release.html?mdfid=282414018&flowid=4827&softwareid=282728525&release=2.2.0.7&relind=AVAILABLE&rellifecycle=&reltype=latest
Here's the release notes link
http://www.cisco.com/en/US/products/ps9932/prod_release_notes_list.html
-Tom
Highlighted
Hi thanks to help,
Ho a new firmware but excepted the H323 over VPN, i don't see really but I"ll upgrade soon.
However, I saw that just before a crash, my CPU was at 100% and 86% is used by kernel !
Often, the CPU is around 20%. rarely more than 30% ....The routeur manage 1 WAN, 2 VPN and routing over 3 VLAN. IPS and proteclink are disable and Firewall with no spécial rules.
Have u an idea hos to know what's happens ?
On log just before crash;
I had :
- 1 error :
Also, I disable The ALG SIP.. If we don't use, it's better to disable it ?
Highlighted
After a look on the kernel log: i have that and every minutes:
Fri Jan 18 11:26:44 2013(GMT +0100)WARNKernel IN=bdg120 OUT=  MAC=33:33:00:00:00:0c:70:f1:a1:XX:XX:XX: 86:dd   SRC=fe80:0000:0000:0000:11bc:d4cc:8232:e 9c4   DST=ff02:0000:0000:0000:0000:0000:0000:0 00c  LEN=194 TC=0 HOPLIMIT=1  FLOWLBL=0 PROTO=UDP SPT=50729 DPT=1900 LEN=154
Component: KERNEL
Fri Jan 18 11:27:00 2013(GMT +0100)WARNKernel IN=bdg120 OUT=  MAC=33:33:00:00:00:0c:70:f1:a1:XX:XX:XX: 86:dd   SRC=fe80:0000:0000:0000:ade2:12f4:2dbf:e 01b   DST=ff02:0000:0000:0000:0000:0000:0000:0 00c  LEN=194 TC=0 HOPLIMIT=1  FLOWLBL=0 PROTO=UDP SPT=54847 DPT=1900 LEN=154
Component: KERNEL
We have 2 différents SRC but after, it's always the same.
What's the aim of theses alerts ?
Highlighted
Ok now, After a reboot: I saw
at Jan 1 00:01:55 2000(GMT +0000)
EMER
Kernel
Initialzing Factory defaults modules
Component: KERNEL
Sat Jan 1 01:03:14 2000(GMT +0100)
ERROR
System
dbRecordValueGet failed for respondIdentd column
Component:                LOGGING
Sat Jan 1 01:03:26 2000(GMT +0100)
ERROR
System
sslRemoteMgmtHandler Invoked
Component: SSLVPN
Sat Jan 1 01:03:51 2000(GMT +0100)
ERROR
System
umiIoctl (UMI_COMP_FIREWALL, UMI_CMD_DB_UPDATE(4)) failed.                table=DhcpRelay row=1
Component: EVTDSPTCH
ERROR
System
umiIoctl (UMI_COMP_FIREWALL, UMI_CMD_DB_UPDATE(4)) failed.                table=DhcpRelay row=2
ERROR
System
umiIoctl (UMI_COMP_FIREWALL, UMI_CMD_DB_UPDATE(4)) failed.                table=DhcpRelay row=3
ERROR
System
umiIoctl (UMI_COMP_FIREWALL, UMI_CMD_DB_UPDATE(4)) failed.                table=DhcpRelay row=4
etc ...etc .. until:
Fri Jan 18 11:53:43 2013(GMT +0100)
ERROR
System
[BONJOUR_ERROR]: DNSServiceRegister returned err=0
Component:                PLATFORM
ERROR
System
[BONJOUR_ERROR]: De-Registering the service
Component:                PLATFORM
ERROR
System
[BONJOUR_ERROR]: Service De-Registration Failed
Component:                PLATFORM
ERROR
System
[BONJOUR_ERROR]: Error in executing DB update handler
Component: PLATFORM
ERROR
System
/pfrm2.0/bin/bonjourConfig /tmp/system.db 9                bonjourRegisteredServices 42 failed. status=-1
Component:                PLATFORM
ERROR
System
umiIoctl (UMI_COMP_PLATFORM, UMI_CMD_DB_UPDATE(4)) failed.                table=bonjourRegisteredServices row=42
Fri Jan 18 11:53:44 2013(GMT +0100)
ERROR
System
Component:                PLATFORM
ERROR
System
Component:                PLATFORM
Highlighted
Advocate
Hi Ghislain, for log review and such, this should be taken up with the support center. There is not a documentation of what the log entry means and a lot of times it would be guess work. Usually engineering / tier2 have to investigate what the specific error codes mean instead of the generalized batch.
Here's the SBSC numbers
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
-Tom
Highlighted
Hy,
thanks to help,
I tried to upgrade the firmware to 2.2.0.7 but, the WAN interface was still down ....I saw there is a new value "Service" ...but even if WAN is allright after modifie that value , The routeur crash and crash again every 20 minutes. So I downgrade to 2.1.7. It's crashing now 2ou 3 time per day.
- Also at Each reboot, the routeur lost its time set... and restart in 2008 or worst. Is it normal ?
- Also, for 3 month, if the routeur has been upgraded from 1.1.65 to 2.1.7 and to 2.2.0.7 , do you think that a factory reset will can do something ?
Highlighted
Advocate
-Tom
Highlighted
I did a default and did my config manually.  It seems stable.
We also swap the modem and it's ok.
Thx a lot. I Hope it's allright.
Beginner
I am using since 2012 and I
I am using since 2012 and I didn't have this problem since 4-5 days ago.
My firmware: 2.2.0.7
What do you suggest?
