Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
1936
Highlighted
Beginner
Site to Site VPN with RV042 and WRV210 with DynDNS and PAT
                   Hai
                   Following is  my Scenario.
                   In head office I will have RV042 and in Branch WRV210. I have a server in HO and Client machines at branches. Need a synchronization between server and clients. Both server and client may initiate the traffic. So two way communication is required. The solution is Gateway to Gateway VPN.
Connectivity at head office
Internet--DSL Router ---> RV042 -----> Application Server
Connectivity at Branch
Internet -- 3Gmodem Router --->WRV210 ------Application Client machines
                  In head office i have static global which can be configured on RV042 internet interface direcly.
                  In branch I plan to work with DynDNS. In the branch WRV210 will be connected to LAN port of 3G modem Router. So the internet interface
   of WRV210 will not have public ip. it  will be a private ip address. I tried to configure port address translation for IP Sec in 3G router.
                After above configuration setup. I found tunnel status as " Waiting for connection"
                In the VPN log I found " Expected < Public IP> but peer is <private IP>.
                I do not know the Head office RV042 able to see the private ip nated behind global. Any how tunnel is not up and it not working.
                If anybody has suggetions ,it will be great.
Everyone's tags (5)
2 REPLIES 2
Highlighted
Rising star
Good morning
Thanks for using our forum
Hi Mohamed my name is Johnnatan and I am part of the Small business Support community.I´ve seen your post, and you can configure your VPN without any problem using  the configuration above.
You can use a domain in the Branch (in this case DynDns)  and in your HO you can use a static IP.Let me share with you some documents in order to help you.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3294
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=352
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3094
I hope you find this answer useful, if it was satisfactory for you, please mark the question as Answered. Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
Highlighted
Beginner
Hello Mohamed,
I am working on your case. Can you please tell me the model of your 3G modem Router and whether the router supports VPN passthrough/NAT traversal ?
Swati Venkitachalam
Small Business Content Developer
