Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
32513
SSL VPN Issues with Internet Explorer
Well, first you need 64-bit Internet Explorer to run web base VPN for SA500 series devices (we use SA540). After we figured that out, we still can't get past SSL VPN Client install on client computers. It either keeps reloading the webpage or just does nothing at all. Any insights?
Also, which CA are you guys using for SSL VPN? Godaddy's certificates aren't compatible as I just found out hard way.
1 ACCEPTED SOLUTION
Tom Watts
Advisor
Hi Qasim,
The issue seems to be more localized with windows blocking everything. I actually spent considerable time working on this yesterday to finally make it work with a 64 bit vista and a 64 bit window 7 machines.
The few things I did to have some success;
Tools -> Internet Options -> Security -> Trusted Sites
  • Move to low
  • Disable protected mode
  • Click sites then add the SSL VPN page to be a trusted member
  • While adding the trusted site, uncheck "Require server verification for all sites on this zone"
Tools -> Internet Options -> Advanced -> Security section
  • Enable "Allow sofware to run or install even if the signature is invalid"
Additionally, you should download the Microsoft Visual C++ Distribution 2010 and ensure you're running the latest version of Java.
These are the things I had to do to allow Windows to let me connect. I hope this has some help for you.
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
6 REPLIES 6
Tom Watts
Advisor
Hi Qasim,
  • Move to low
-Tom
Thanks Thomas. I'll give it a try.
Nope, I wasn't able to resolve this. Problems seems to be with IE version 8. I was surprised to see my Win7 X64 machines work without any workarounds. I am investigating this matter furthure and will keep you informed. Thanks.
Here's the error:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; InfoPath.1; .NET4.0C; .NET4.0E)
Timestamp: Fri, 24 Aug 2012 14:46:13 UTC
Message: Overflow: 'XTunnel1.ServerPort'
Line: 259
Char: 1
Code: 0
Qasim, thank you for the continued effort to resolve your issue. Aside from the configuration that we have accomplished here
https://supportforums.cisco.com/thread/2168382
In addition, the resolution relied on the Active Directory, to set the SSL client accounts the same as the AD. But additionally modifying the computers with a router to allow the outside subnet in to the private network. You have also added any machine that runs Windows Server 2003R2 or later does not require any routes.
Thanks.
-Tom
Please rate helpful posts
mthomas1999
Beginner
Hey guys needs help with SSL VPN config.  I have ASA 5505 version 9.1 and setup SSL VPN which i can connect to locally but not from the internet.  From the internet i get prompted to access the secure https site then when i connect i get a blank page - connection was reset message.
Here is my config -
ZEPPELIN# show run
: Saved
ASA Version 9.1(1)
hostname ZEPPELIN
domain-name MIWEBPORTAL.com
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
ip local pool SSLVPNPool 172.19.19.20-172.19.19.29 mask 255.255.255.0
interface Ethernet0/0
description ISP-MODEM
switchport access vlan 20
interface Ethernet0/1
shutdown
interface Ethernet0/2
description INTERNAL-NET
switchport access vlan 19
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
description DMZ
switchport access vlan 99
interface Ethernet0/7
description DMZ
interface Vlan1
shutdown
no nameif
no security-level
no ip address
interface Vlan19
nameif MYNETWORK
security-level 100
ip address 172.19.19.1 255.255.255.0
interface Vlan20
description DHCP-MODEM-INTERNET
mac-address XXX.XXX.XXX
nameif INTERNET
security-level 0
ip address dhcp setroute
interface Vlan99
description DMZ-NET
no forward interface Vlan19
nameif MYDMZ
security-level 50
ip address 192.168.99.1 255.255.255.0
ftp mode passive
dns server-group DefaultDNS
object network MYNETWORK
subnet 172.19.19.0 255.255.255.0
object network MYDMZ
subnet 192.168.99.0 255.255.255.0
object network Media-PC
host 172.19.19.29
description Media-PC
object network FOSCamera
host 172.19.19.99
object service USBCAM_SVC
service tcp source eq 20019 destination eq 20019
object network USBCamera
host 172.19.19.199
object network NETWORK_OBJ_172.19.19.16_28
subnet 172.19.19.16 255.255.255.240
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list MYNETWORK_access_in extended deny ip object Media-PC any
access-list MYNETWORK_access_in extended permit ip any any
access-list FOSCAM-in extended permit tcp any object FOSCamera eq 51999 log inactive
pager lines 24
logging enable
logging asdm informational
mtu MYNETWORK 1500
mtu INTERNET 1500
mtu MYDMZ 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-712.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (MYNETWORK,INTERNET) source static any any destination static NETWORK_OBJ_172.19.19.16_28 NETWORK_OBJ_172.19.19.16_28 no-proxy-arp route-lookup
nat (MYNETWORK,INTERNET) dynamic interface
nat (MYDMZ,INTERNET) dynamic interface
nat (MYNETWORK,INTERNET) static interface service tcp 51999 51999
nat (MYNETWORK,INTERNET) static interface service tcp 52999 52999
access-group MYNETWORK_access_in in interface MYNETWORK
access-group FOSCAM-in in interface INTERNET
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
http server enable 1999
http 172.19.19.0 255.255.255.0 MYNETWORK
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map INTERNET_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map INTERNET_map interface INTERNET
crypto ca trustpoint localtrust
enrollment self
subject-name CN=sslvpn.miwebportal.com
keypair sslvpnkey
crl configure
crypto ca trustpool policy
crypto ca certificate chain localtrust
certificate 456ad952
    3082020b 30820174 a0030201 02020445 6ad95230 0d06092a 864886f7 0d010105
    0500304a 311f301d 06035504 03131673 736c7670 6e2e6d69 77656270 6f727461
    6c2e636f 6d312730 2506092a 864886f7 0d010902 16185a45 5050454c 494e2e4d
    49574542 504f5254 414c2e63 6f6d301e 170d3134 30313230 31353030 31365a17
    0d323430 31313831 35303031 365a304a 311f301d 06035504 03131673 736c7670
    6e2e6d69 77656270 6f727461 6c2e636f 6d312730 2506092a 864886f7 0d010902
    16185a45 5050454c 494e2e4d 49574542 504f5254 414c2e63 6f6d3081 9f300d06
    092a8648 86f70d01 01010500 03818d00 30818902 818100dc e35bb0a1 1ff13a12
    05772cc7 50ec3c48 251749ca 3b724da9 7d9f90f9 e8d4fd85 9ee22d62 cc62275a
    ce637497 914d30a6 4c3420ac ef11582b 7d931f4f 0ef3be12 30f9a8d1 dcef2361
    25dd914b 31a6827d f33c6934 271d4dd9 ba422c0f ff3379dd da29211e 7e92d30c
    fb150022 a199b904 c41e8d9c 7ce54fa1 ce118b9e bd101b02 03010001 300d0609
    2a864886 f70d0101 05050003 8181009c 8ee9b89f f84aebd3 add84b20 6e8a5189
    7d4851cb 2a849e4f 48000537 7151661a f15d0abe 9a97540d fdc86946 c84ace41
    d54d9963 1ad05ae1 5044e2a0 62992d62 4dbbbd7e bc2558fe 9a1fed03 a4c8de2b
    79ffb5da 6bb9493d 30dfaa51 2c0d9765 a7c0f44b 7296c670 56515b1e cb342a8f
    ae04ccc1 3548debb d5435100 d6b47f
  quit
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable INTERNET client-services port 443
crypto ikev2 remote-access trustpoint localtrust
telnet timeout 5
ssh 172.19.19.0 255.255.255.0 MYNETWORK
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd lease 691200
dhcpd ping_timeout 750
dhcpd address 172.19.19.18-172.19.19.28 MYNETWORK
dhcpd enable MYNETWORK
dhcpd address 192.168.99.9-192.168.99.19 MYDMZ
dhcpd enable MYDMZ
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point localtrust MYNETWORK
ssl trust-point localtrust INTERNET
webvpn
enable MYNETWORK
enable INTERNET
anyconnect image disk0:/anyconnect-win-2.5.2019-k9.pkg 1
anyconnect profiles AnyConnectSSL_client_profile disk0:/AnyConnectSSL_client_profile.xml
anyconnect enable
tunnel-group-list enable
group-policy SSLGrpPolicy internal
group-policy SSLGrpPolicy attributes
vpn-tunnel-protocol l2tp-ipsec
webvpn
  url-list none
group-policy DfltGrpPolicy attributes
dns-server value 8.8.8.8
vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
group-policy GroupPolicy_AnyConnectSSL internal
group-policy GroupPolicy_AnyConnectSSL attributes
wins-server none
dns-server value 172.19.19.1
vpn-tunnel-protocol ikev2 ssl-client
default-domain value MIWEBPORTAL.com
webvpn
  anyconnect profiles value AnyConnectSSL_client_profile type user
username MThomas-x password I3iNtAfVbtN12L4e encrypted privilege 15
tunnel-group AnyConnectSSL type remote-access
tunnel-group AnyConnectSSL general-attributes
address-pool SSLVPNPool
default-group-policy GroupPolicy_AnyConnectSSL
tunnel-group AnyConnectSSL webvpn-attributes
group-alias AnyConnectSSL enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:a065cc3cb4d3de5eeaf81e7632cac831
: end
