SSL VPN with MAC OSX issues
awahabmirza
Beginner
Beginner
Does SA520 support SSLVPN for MAC OSX, if so, how do we get it working. If not, does SA520 support IPSEC VPN for MAC OS X, I have tried both setup, but none works for the MAC users.
mpyhala
Rising star
Rising star
Hi Abdul,
Please see the Release Notes for the SA500 series for information about using SSL VPN with Mac OSX:
http://www.cisco.com/en/US/docs/security/multi_function_security/multi_function_security_appliance/sa_500/release/sa500_MR5_v2.1.71.pdf
There is a known issue and a workaround.
You can also try IP Securitas (free) for IPSec connections to the SA500 series. Please see the following document:
http://www.cisco.com/en/US/docs/security/multi_function_security/multi_function_security_appliance/sa_500/technote/note/SA500_mac_appnote.pdf
Please let us know if this helps you or if you have any questions.
Thanks, I upgraded SA520 to 2.1.71. and followed the guidelines proivded for IPSec Securitas, however I am still having issues with my VPN, here are my logs, would appreicate help.
Date          Severity          Facility          Source IP          Destination IP          Log Data
Thu Mar 29 19:48:43 2012(GMT +0100)          INFO          VPN                                 Remote configuration for identifier "remote.com" found
Component: VIPSECURE
Thu Mar 29 19:48:43 2012(GMT +0100)          INFO          VPN                                 Received request for new phase 1 negotiation: y.y.y.4[500]<=>x.x.x.190[428]
Thu Mar 29 19:48:43 2012(GMT +0100)          INFO          VPN                                 Beginning Aggressive mode.
Thu Mar 29 19:48:43 2012(GMT +0100)          INFO          VPN                                 Received unknown Vendor ID
Thu Mar 29 19:48:43 2012(GMT +0100)          INFO          VPN                                 Received Vendor ID: DPD
Thu Mar 29 19:48:44 2012(GMT +0100)          INFO          VPN                                 ISAKMP-SA established for y.y.y.4[500]-x.x.x.190[428] with spi:2c00acc284208fe6:975864355e849794
Thu Mar 29 19:48:44 2012(GMT +0100)          INFO          VPN                                 Sending Informational Exchange: notify payload[INITIAL-CONTACT]
Thu Mar 29 19:48:44 2012(GMT +0100)          INFO          VPN                                 Responding to new phase 2 negotiation: y.y.y.4[0]<=>x.x.x.190[0]
Thu Mar 29 19:48:44 2012(GMT +0100)          INFO          VPN                                 Using IPsec SA configuration: anonymous
Thu Mar 29 19:48:44 2012(GMT +0100)          INFO          VPN                                 Re-using previously generated policy: 172.27.126.50/32[0] 101.101.101.0/24[0] proto=any dir=in
Thu Mar 29 19:48:44 2012(GMT +0100)          INFO          VPN                                 IPsec-SA established: ESP/Tunnel x.x.x.190->y.y.y.4 with spi=264813278(0xfc8bade)
Thu Mar 29 19:48:44 2012(GMT +0100)          INFO          VPN                                 IPsec-SA established: ESP/Tunnel y.y.y.4->x.x.x.190 with spi=232749452(0xddf798c)
Thu Mar 29 19:49:09 2012(GMT +0100)          INFO          VPN                                 Sending Informational Exchange: delete payload[]
Thu Mar 29 19:49:09 2012(GMT +0100)          INFO          VPN                                 an undead schedule has been deleted: 'pk_recvupdate'.
Thu Mar 29 19:49:42 2012(GMT +0100)          INFO          VPN                                 Purged ISAKMP-SA with proto_id=ISAKMP and spi=2c00acc284208fe6:975864355e849794.
Thu Mar 29 19:49:43 2012(GMT +0100)          INFO          VPN                                 ISAKMP-SA deleted for y.y.y.4[500]-x.x.x.190[428] with spi:2c00acc284208fe6:975864355e849794
Recognize Your Peers
