SSLVPN portal design
Is there a way to change the look of SSLVPN portal byond what utility offers? I'd like the Tunnel software download link to be on front page so users don't get lost in navigation. Any ideas?
Thanks.
Tom Watts
Advisor
Advisor
Hi Qasim,You can modify title, banner heading, banner message, security settings, and access type (VPN tunnel, port forwarding, or both). But, the main login won't be the tunnel adapter install page. You can also try to use the features SSL VPN Portal Pages to Display and see if that will help simplify some.
By the way, did you manage to get the SSL to connect from your other post?
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
Advisor
Advisor
-Tom
Recognize Your Peers
