Adding Wireless Capability to RV160
566
Beginner
I recently purchased an RV160W for an individual who was having substantial trouble with her ISP router.
Unfortunately, I received the wrong model in the mail, the RV160.
Is there a low cost solution anyone is aware of to attach a wireless access point to this well built device? The reason I ask is because, for reasons related to , it can be beneficial to have a wireless access point as a separate add on.
Thank you!
Patrick
1 Comment
In case you have purchased that product recently then you may check once with your reseller to replace that RV160 with a RV160W Router. Otherwise, you may check the below mentioned link once for Cisco Small Business 100 series Access Points in case that can cater your purpose…
https://www.cisco.com/c/en/us/products/wireless/small-business-100-series-wireless-access-points/index.html
