Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
3rd Party Applications - Solutions - Cisco Smart Business Communication Systems
6053
[toc:faq]
Overview
3rd Party Applications provide integration between voice, video and data IP communications. With respect to Smart Business Communication Systems (SBCS) support, 3rd party applications can be categorized into the following two categories:
SBCS System Release: Applications that has been fully tested as a part of a SBCS System Release. These applications are officially supported by Cisco TAC. Please refer to SBCS Solutions Page for a list of 3rd party applications tested with the latest SBCS release.
Unvalidated: Applications not yet been fully tested or supported by Cisco TAC, and therefore not officially supported by Cisco. These applications are marked red on this page. Please read the notes for each application to determine if this functionality is suitable for your deployment and support requirements.
SBCS System Release Applications
StoneVoice SkyStone
Nokia Intellisync Call Connect for Cisco
Nokia Intellisync Call Connect Overview & datasheet
Client download and documentation
Nokia E61i User Guide
IPCelerate IPSmartSuite
FAQ
What do I need to order for using Nokia Intellisync Call Connect?
The Cisco Smart Business Communications System supports the Nokia Dual Mode E-series cell phones. The user must purchase the Nokia Dual Mode E-series cell phones from a qualified Nokia dealer and must purchase the software license for the Nokia Skinny Client Control Protocol (SCCP) client, which is installed on the Nokia E-series phones to enable communication over the WLAN infrastructure to the Unified 500 Series. The base unit includes the Unified Communications Manager Express software and the Cisco Unified IP Phone user licenses (UL). When ordering the Nokia SCCP license for Cisco Unified Communications Manager Express, use the spare SKU, where the phone model number SKU includes an equals sign (=) at the end to avoid the purchase of a duplicate user license. License SKUs and List Price for Nokia SCCP licenses are on Table 6 of the Image:padlock.JPGCisco Smart Business Communication Systems Ordering Guide (PARTNER ONLY)
What version of TAPI is supported by UC500?
UC500 supports TAPI version 2.1 that's based on CME release 4.0. Here's some information for TAPI Setup Guide
Where can I find information regarding API's for UC500?
UC500 supports TAPI and XML API for 3rd party application development. Details regarding each API can be found below: TAPI Developer Guide for Cisco CME/SRST
XML Provisioning Guide for Cisco CME/SRST
Where can I receive support for developing custom applications for UC500?
The Developer Services Program is a subscription based program that provides services and support for customers and partners who are leveraging Cisco interfaces in their development projects. For further details on the program, please refer to the Developer Services FAQ or email developer-support@cisco.com.
Unvalidated 3rd Party Applications
Cyberdata Callbox
Cyberdata has designed the“Callbox Unit", an affordable door access solution for SMB customers. The Callbox provides the following functionality for UC500/SBCS:
  1. The user can open a door remotely by dialing a set of digits from an IP Phone.
  2. A user at the Callbox can dial the operator's IP phone from the outside by pressing "Call" button on the Callbox.
This solution is scheduled to go though Cisco Technology Developer Program lab testing in the near future. When this testing is complete, the Cyberdata solution will be supported by Cisco TAC.
Further details are available in the following application note.
Gold Mine CRM integration
With integration of GoldMine CRM to Cisco Unified Communications 500 Series, inbound calls to the agent’s phone will result in a call popup on the desktop with the contact’s information populated from the GoldMine database.
An agent can control the IP phone by using the Tapi Link keypad and perform the following operations:
  1. Answer inbound calls
  2. Make outbound calls by dialing a number
  3. Make outbound calls using speed dials configured in Tapi Link
  4. Click to dial a contact’s phone number (phone 1, phone 2 and phone 3)
  5. Last number redial
  6. Hold and resume calls Toggle between two active calls
  7. Execute a blind transfer
  8. Execute a supervised transfer
Further details are available in the following guide: Integrating UC500 with Goldmine CRM
Act! by Sage CRM integration
With ACT! CRM Integration to Cisco Unified Communications 500 Series, inbound calls to the agent’s phone will result in a call popup on the desktop with the contact’s information populated from the ACT! CRM database. An agent can control the IP phone by using the TAPI.NET add-on to perform the following operations:
  3. Click to dial a contact’s phone number (phone 1, phone 2 and phone 3)
Further details are available in the following guide: Integrating UC500 with ACT! by Sage CRM
Note: Links that will require partner-level access will have a lock icon Image:padlock.JPG next to it. Further details for becoming a Cisco Registered Partner is available here
