This device will be detected by CDP and CAM tables, so it must be plugged into a supported switch.
Device Configuration Backup and Restore
You must provide credentials in order for device configuration and backup and restore to function properly. Credentials are entered under Credentials > Login and Credentials > Enable in the Device Information window on the portal.
Upgrade Firmware
As long as access credentials are provided this should function properly. If the device has defined a boot load with the boot system command, firmware updates do not occur, as the administrator has defined a specific load intended for the device.
