This application note describes the steps required to configure the Cisco WIP310 Wireless-G IP Phone with the SPA9000 Voice System using the SPA9000 Setup Wizard version 2.1
Looking to add a redundant core switch to our infrastructure.We are a small business with 80 computers and 8 servers. We already utilise SG500 The current Setup is a Tier2 architecture.Firewall X0 (VLAN50) corporate to 4x SG500 stack - 7 servers...
view more
Need help please, I have Cisco SG-35028P switch , I have a task of creating two or three VLAN's with DHCP and internet should work for the clients. Can you please guide me. communication within vlan is not required. I have 1) Ci...
view more
Hi, I have Cisco RV345, and looking for a way to isolate 3 devices (LAN Ports) that communicate using Layer 2. VLAN 1 - Standard and running DHCP (ipv4 only) - inter-vlan disabledVLAN 3 - Standard and running DHCP (ipv4 only) - inter-vlan d...
view more
I have a dot1x setup on a sg300: dot1x system-auth-controlencrypted radius-server key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxradius-server host x.x.x.x usage dot1.xinterface gigabitethernet5dot1x host-mode single-hostdot1x violation-mode shutdown trap 10dot1...
view more
