This application note drives the partner to configure the SPA9000 and the SPA8000(s) in the Analog Phone IP PBX configuration using the SPA9000 Analog IP PBX Setup Wizard v1.0.
Hello Community, I have installed a CISCO ATA191 and trying to connect it with the German Telekom Cloud PBX Environment.Device is not getting sucessfully registered. Please find below the last entries from the LogFile.Any Explanation about the meanin...
view more
I was setup SSL VPN. on my RV340 Mandatory Gateway SettingsGateway Interface: WAN1Gateway Port: 8443Certificate File: DefaulClient Address Pool: 10.11.12.0Client Netmask: 255.255.255.0 My LAN/DHCP Settings IP Version 4DHCP Mode: server...
view more
I am trying to setup a site to site vpn to 2 remote sites where the remote sites have MIFI. if I use the RV160w at the remote sites, is there an issue to leverage the address from the wireless MIFI to bind the tunnel to back to the RV160 in the main...
view more
Hi all. This is my first time setting up a home lab and I feel like the current typology I have is extremely inefficient. I have posted my current typology below and will offer a brief explanation of what I have done. Essentially what I have done is I use...
view more
Yesterday I ended up checking for new RV340 firmware and discovered the CIsco Security Advisory on the Authenticated Remote Code Execution Vulnerabilities. I downloaded and installed the new firmware, version 1.0.03.21. However, with both p...
view more
