The attached files are based on the Broadsoft 7.4.3 CPE kits for the SPA3xx, SPA5xxG, and SPA525G IP phones. The attached files contain some non-critical, phone-related changes.
The official 7.4.3 CPE kits are available from the Broadsoft Xchange [http://xchange.broadsoft.com]
Note: SPA30x and SPA50x phones use the same CPE kit and same phone software
The compressed attachment files contain only the following xml files:
File Name | Example |
<model>.xml | 504.xml |
<model>_MAC.xml | 504_MAC.xml |
<model>System.xml | 504System.xml |
MAC_<model>Keys.xml | MAC_504Keys.xml |
The following limited distribution files are not posted here:
The full CPE kit is available from any of the following:
<end>
The full CPE kit is no longer available from
as page doesn't exists at all.
Reference removed from document.
