When you install CIPC SW on your client PC, you have the phone load. You configure its TFTP server as 10.1.1.1 and you are ready to rock and roll.
In this example, I am running CIPC version 7.0.2.0 (you will notcie that in the terminal monitor display below when it registers)
The PC can then be connected one of two ways:
- locally on the data VLAN of the UC520
- via the VPN Server of the UC520 (using the Cisco VPN Client when PC is remote)
When connecting to the CME device (in our case running on UC520) it will ask for its Configuration File.
You will see the name SEPxxxxxxxxxxxx, which is Skinny Enp Point <MAC of your PC>
When you open CCA, you will see the Phone Type CIPC and notice the MAC Address of the PC Interface use for the connection.
Now you would configure it as any other phone. CIPC button behavior is like the 7970 in terms of button support.
Topology view:
But getting back to this SEP Config file, the file it looks for on the UC520 isnt on Flash:...
When it doesnt find it, it goes for the default file in System:/ITS:
You can see this by opening a SSH session to the UC520 and turning on debugging for TFTP Events and TFTP Packets.
May 29 17:52:01.908: TFTP: Server request for port 4970, socket_id 0x86A9AC30 for process 172
May 29 17:52:01.908: TFTP: read request from host 192.168.10.13(4970) via BVI1
May 29 17:52:01.908: TFTP: Looking for CTLSEP00218656CEE2.tlv
May 29 17:52:01.908: TFTP: Sending error 1 No such file
May 29 17:52:02.952: TFTP: Server request for port 4970, socket_id 0x86A9AC30 for process 172
May 29 17:52:02.952: TFTP: read request from host 192.168.10.13(4970) via BVI1
May 29 17:52:02.952: TFTP: Looking for SEP00218656CEE2.cnf.xml
May 29 17:52:02.952: TFTP: Opened system:/its/XMLDefaultCIPC.cnf.xml, fd 10, size 1176 for process 172
May 29 17:52:02.952: TFTP: Sending block 1 (retry 0), socket_id 0x86A9AC30
May 29 17:52:02.956: TFTP: Received ACK for block 1, socket_id 0x86A9AC30
May 29 17:52:02.956: TFTP: Sending block 2 (retry 0), socket_id 0x86A9AC30
May 29 17:52:02.956: TFTP: Received ACK for block 2, socket_id 0x86A9AC30g
May 29 17:52:02.956: TFTP: Sending block 3 (retry 0), socket_id 0x86A9AC30
May 29 17:52:02.960: TFTP: Received ACK for block 3, socket_id 0x86A9AC30
May 29 17:52:02.960: TFTP: Finished system:/its/XMLDefaultCIPC.cnf.xml, time 00:00:00 for process 172
Then the phone is happy (has what it wants and is registered)
May 29 17:52:14.225: %IPPHONE-6-REG_ALARM: 25: Name=SEP00218656CEE2 Load= 7.0.2.0 Last=Initialized
May 29 17:52:16.341: %IPPHONE-6-REGISTER: ephone-12:SEP00218656CEE2 IP:192.168.10.13 Socket:15 DeviceType:Phone has registered.
If you open system:/its and its the very last file (in bold).
SBCS-Main#dir system:/its
Directory of system:/its/
227 -rw- 377 <no date> ATADefault.cnf.xml
5 drwx 0 <no date> austria
7 drwx 0 <no date> canada
9 drwx 0 <no date> denmark
16 drwx 0 <no date> france
23 drwx 0 <no date> germany
30 drwx 0 <no date> italy
91 drwx 0 <no date> japan
37 drwx 0 <no date> netherlands
44 drwx 0 <no date> norway
51 drwx 0 <no date> portugal
58 drwx 0 <no date> russia
4 -rw- 75 <no date> SEPDEFAULT.cnf
66 drwx 0 <no date> spain
73 drwx 0 <no date> sweden
80 drwx 0 <no date> switzerland
82 drwx 0 <no date> united_kingdom
84 drwx 0 <no date> united_states
229 -rw- 3342 <no date> XMLDefault.cnf.xml
230 -rw- 1101 <no date> XMLDefault521G.cnf.xml
231 -rw- 1101 <no date> XMLDefault524G.cnf.xml
232 -rw- 1100 <no date> XMLDefault525G.cnf.xml
110 -rw- 513 <no date> XMLDefault7902.cnf.xml
111 -rw- 992 <no date> XMLDefault7905.cnf.xml
112 -rw- 1225 <no date> XMLDefault7906.cnf.xml
113 -rw- 576 <no date> XMLDefault7910.cnf.xml
114 -rw- 1225 <no date> XMLDefault7911.cnf.xml
115 -rw- 992 <no date> XMLDefault7912.cnf.xml
116 -rw- 992 <no date> XMLDefault7920.cnf.xml
117 -rw- 1187 <no date> XMLDefault7921.cnf.xml
118 -rw- 1187 <no date> XMLDefault7925.cnf.xml
119 -rw- 1225 <no date> XMLDefault7931.cnf.xml
120 -rw- 515 <no date> XMLDefault7935.cnf.xml
121 -rw- 535 <no date> XMLDefault7936.cnf.xml
122 -rw- 1230 <no date> XMLDefault7937.cnf.xml
124 -rw- 1273 <no date> XMLDefault7940-7914-1.cnf.xml
129 -rw- 1416 <no date> XMLDefault7940-7914-2.cnf.xml
125 -rw- 1271 <no date> XMLDefault7940-7915-12-1.cnf.xml
130 -rw- 1412 <no date> XMLDefault7940-7915-12-2.cnf.xml
126 -rw- 1271 <no date> XMLDefault7940-7915-24-1.cnf.xml
131 -rw- 1412 <no date> XMLDefault7940-7915-24-2.cnf.xml
127 -rw- 1271 <no date> XMLDefault7940-7916-12-1.cnf.xml
132 -rw- 1412 <no date> XMLDefault7940-7916-12-2.cnf.xml
128 -rw- 1271 <no date> XMLDefault7940-7916-24-1.cnf.xml
133 -rw- 1412 <no date> XMLDefault7940-7916-24-2.cnf.xml
123 -rw- 1099 <no date> XMLDefault7940.cnf.xml
134 -rw- 1225 <no date> XMLDefault7941.cnf.xml
135 -rw- 1225 <no date> XMLDefault7941GE.cnf.xml
136 -rw- 1225 <no date> XMLDefault7942.cnf.xml
137 -rw- 1225 <no date> XMLDefault7945.cnf.xml
139 -rw- 1273 <no date> XMLDefault7960-7914-1.cnf.xml
144 -rw- 1416 <no date> XMLDefault7960-7914-2.cnf.xml
140 -rw- 1271 <no date> XMLDefault7960-7915-12-1.cnf.xml
145 -rw- 1412 <no date> XMLDefault7960-7915-12-2.cnf.xml
141 -rw- 1271 <no date> XMLDefault7960-7915-24-1.cnf.xml
146 -rw- 1412 <no date> XMLDefault7960-7915-24-2.cnf.xml
142 -rw- 1271 <no date> XMLDefault7960-7916-12-1.cnf.xml
147 -rw- 1412 <no date> XMLDefault7960-7916-12-2.cnf.xml
143 -rw- 1271 <no date> XMLDefault7960-7916-24-1.cnf.xml
148 -rw- 1412 <no date> XMLDefault7960-7916-24-2.cnf.xml
138 -rw- 1099 <no date> XMLDefault7960.cnf.xml
150 -rw- 1399 <no date> XMLDefault7961-7914-1.cnf.xml
155 -rw- 1542 <no date> XMLDefault7961-7914-2.cnf.xml
151 -rw- 1397 <no date> XMLDefault7961-7915-12-1.cnf.xml
156 -rw- 1538 <no date> XMLDefault7961-7915-12-2.cnf.xml
152 -rw- 1397 <no date> XMLDefault7961-7915-24-1.cnf.xml
157 -rw- 1538 <no date> XMLDefault7961-7915-24-2.cnf.xml
153 -rw- 1397 <no date> XMLDefault7961-7916-12-1.cnf.xml
158 -rw- 1538 <no date> XMLDefault7961-7916-12-2.cnf.xml
154 -rw- 1397 <no date> XMLDefault7961-7916-24-1.cnf.xml
159 -rw- 1538 <no date> XMLDefault7961-7916-24-2.cnf.xml
149 -rw- 1225 <no date> XMLDefault7961.cnf.xml
161 -rw- 1399 <no date> XMLDefault7961GE-7914-1.cnf.xml
166 -rw- 1542 <no date> XMLDefault7961GE-7914-2.cnf.xml
162 -rw- 1397 <no date> XMLDefault7961GE-7915-12-1.cnf.xml
167 -rw- 1538 <no date> XMLDefault7961GE-7915-12-2.cnf.xml
163 -rw- 1397 <no date> XMLDefault7961GE-7915-24-1.cnf.xml
168 -rw- 1538 <no date> XMLDefault7961GE-7915-24-2.cnf.xml
164 -rw- 1397 <no date> XMLDefault7961GE-7916-12-1.cnf.xml
169 -rw- 1538 <no date> XMLDefault7961GE-7916-12-2.cnf.xml
165 -rw- 1397 <no date> XMLDefault7961GE-7916-24-1.cnf.xml
170 -rw- 1538 <no date> XMLDefault7961GE-7916-24-2.cnf.xml
160 -rw- 1225 <no date> XMLDefault7961GE.cnf.xml
172 -rw- 1399 <no date> XMLDefault7962-7914-1.cnf.xml
177 -rw- 1542 <no date> XMLDefault7962-7914-2.cnf.xml
173 -rw- 1397 <no date> XMLDefault7962-7915-12-1.cnf.xml
178 -rw- 1538 <no date> XMLDefault7962-7915-12-2.cnf.xml
174 -rw- 1397 <no date> XMLDefault7962-7915-24-1.cnf.xml
179 -rw- 1538 <no date> XMLDefault7962-7915-24-2.cnf.xml
175 -rw- 1397 <no date> XMLDefault7962-7916-12-1.cnf.xml
180 -rw- 1538 <no date> XMLDefault7962-7916-12-2.cnf.xml
176 -rw- 1397 <no date> XMLDefault7962-7916-24-1.cnf.xml
181 -rw- 1538 <no date> XMLDefault7962-7916-24-2.cnf.xml
171 -rw- 1225 <no date> XMLDefault7962.cnf.xml
183 -rw- 1399 <no date> XMLDefault7965-7914-1.cnf.xml
188 -rw- 1542 <no date> XMLDefault7965-7914-2.cnf.xml
184 -rw- 1397 <no date> XMLDefault7965-7915-12-1.cnf.xml
189 -rw- 1538 <no date> XMLDefault7965-7915-12-2.cnf.xml
185 -rw- 1397 <no date> XMLDefault7965-7915-24-1.cnf.xml
190 -rw- 1538 <no date> XMLDefault7965-7915-24-2.cnf.xml
186 -rw- 1397 <no date> XMLDefault7965-7916-12-1.cnf.xml
191 -rw- 1538 <no date> XMLDefault7965-7916-12-2.cnf.xml
187 -rw- 1397 <no date> XMLDefault7965-7916-24-1.cnf.xml
192 -rw- 1538 <no date> XMLDefault7965-7916-24-2.cnf.xml
182 -rw- 1225 <no date> XMLDefault7965.cnf.xml
194 -rw- 1399 <no date> XMLDefault7970-7914-1.cnf.xml
199 -rw- 1542 <no date> XMLDefault7970-7914-2.cnf.xml
195 -rw- 1397 <no date> XMLDefault7970-7915-12-1.cnf.xml
200 -rw- 1538 <no date> XMLDefault7970-7915-12-2.cnf.xml
196 -rw- 1397 <no date> XMLDefault7970-7915-24-1.cnf.xml
201 -rw- 1538 <no date> XMLDefault7970-7915-24-2.cnf.xml
197 -rw- 1397 <no date> XMLDefault7970-7916-12-1.cnf.xml
202 -rw- 1538 <no date> XMLDefault7970-7916-12-2.cnf.xml
198 -rw- 1397 <no date> XMLDefault7970-7916-24-1.cnf.xml
203 -rw- 1538 <no date> XMLDefault7970-7916-24-2.cnf.xml
193 -rw- 1225 <no date> XMLDefault7970.cnf.xml
205 -rw- 1399 <no date> XMLDefault7971-7914-1.cnf.xml
210 -rw- 1542 <no date> XMLDefault7971-7914-2.cnf.xml
206 -rw- 1397 <no date> XMLDefault7971-7915-12-1.cnf.xml
211 -rw- 1538 <no date> XMLDefault7971-7915-12-2.cnf.xml
207 -rw- 1397 <no date> XMLDefault7971-7915-24-1.cnf.xml
212 -rw- 1538 <no date> XMLDefault7971-7915-24-2.cnf.xml
208 -rw- 1397 <no date> XMLDefault7971-7916-12-1.cnf.xml
213 -rw- 1538 <no date> XMLDefault7971-7916-12-2.cnf.xml
209 -rw- 1397 <no date> XMLDefault7971-7916-24-1.cnf.xml
214 -rw- 1538 <no date> XMLDefault7971-7916-24-2.cnf.xml
204 -rw- 1225 <no date> XMLDefault7971.cnf.xml
216 -rw- 1399 <no date> XMLDefault7975-7914-1.cnf.xml
221 -rw- 1542 <no date> XMLDefault7975-7914-2.cnf.xml
217 -rw- 1397 <no date> XMLDefault7975-7915-12-1.cnf.xml
222 -rw- 1538 <no date> XMLDefault7975-7915-12-2.cnf.xml
218 -rw- 1397 <no date> XMLDefault7975-7915-24-1.cnf.xml
223 -rw- 1538 <no date> XMLDefault7975-7915-24-2.cnf.xml
219 -rw- 1397 <no date> XMLDefault7975-7916-12-1.cnf.xml
224 -rw- 1538 <no date> XMLDefault7975-7916-12-2.cnf.xml
220 -rw- 1397 <no date> XMLDefault7975-7916-24-1.cnf.xml
225 -rw- 1538 <no date> XMLDefault7975-7916-24-2.cnf.xml
215 -rw- 1225 <no date> XMLDefault7975.cnf.xml
226 -rw- 1212 <no date> XMLDefault7985.cnf.xml
228 -rw- 1176 <no date> XMLDefaultCIPC.cnf.xml
Thats all it really needs and configuration is then done using CCA and saved in the running-config and start-up config the next time you 'wr mem' or SAVE in the CCA toolbar.
Just posted a note on how to configure shared extension with CIPC and another IP phone using CCA 2.0.
https://www.myciscocommunity.com/docs/DOC-7988
Cheers,
Tomoo
