Overview
The Cisco Monitor Director enables Cisco partners and managed service providers to provide comprehensive 24-hour remote real-time monitoring and management of data and voice services to their small and medium-sized (SMB) customers with 5 to 250 users. Using this solution saves time and money because you can remotely detect, diagnose, and fix problems faster, without having to leave your office. You'll become a trusted advisor to your SMB customers, as you improve the quality of their monitoring service and help them lower operational costs and increase recurring revenue, profit, and cash flow.
Product Information
Brochures
Cisco Monitor Director 1.1.2
Bulletins
Datasheets
Install and Upgrade Guides
Quick Start Guide for Cisco Monitor Director 1.1.2 (SBCS release)
Release Notes
Release Notes for Cisco Monitor Director 1.1.2
Release Notes for Cisco Monitor Director Agent 1.1.2
Supported Devices and Versions
Supported Device Table for Cisco Monitor Director 1.1.2
The SMB Smart Design
The SMB Smart Designs are Validated Commercial Solutions that are primarily designed for partner success. They incorporate comprehensive solution implementation best practices in an easy to follow format to streamline the installation process, reduce deployment risk and increase partner profitability.
Cisco Monitor Director Solution Implementation Guide - (For Cisco Partner Only) This implementation guide provides information and detailed configuration examples for deploying the Cisco Monitor Director Solution. This design provides information about the features and functionality offered by the Graphical User Interface (GUI) of each respective solutions components and is intended to reduce the overall complexity of the system-allowing partners and customers with varying levels of technical knowledge to deploy this design.
FAQ
Cisco Monitor Director 1.1.2 FAQ
