Hi all, I'm new here so please be kind!Bought an SG350-10 switch recently to use in my home labI'm setting a static IP on the switch and all is working fine.. I've got this plugged into an older ASA5505 that has no DHCP configured on the port plugged...
view more
Hello community.I'm trying to add a firewall rule in the RV130W to block access to the router administration page. I'm also trying to add a rule to allow access from a specific machine. But the RV130W won't allow me to add rules in the same LAN subnet. Ca...
view more
I set up a single port forward on this router for UDP only and a couple of times it has stopped accepting connections. It seems like somehow it has got "jammed", because if I change the public port number on the rule, it starts working again on the new po...
view more
Hi,I have the following arrangement:PC1 <-->Port2 SG250(IP.245) Port6<-->Port4 SG250(IP.246) Port2<--> PC2The switches are pretty much set to default except I have upgraded their firmware to latest, set static IPs and enabled IGMP s...
view more
My RV345 suddenly got unresponsive. Not sure why. Now when I reboot the router it works and everything seems fine for the first 7-9 minutes of uptime. Then it becomes unresponsive I am using firmware 1.0.03.21I've done resets...
view more
