Get
the latest new and information the November issue of the Cisco
Small
Business Monthly Newsletter
Configure a speed dial (SD) to an unused line key on a SPA9x2 phone.
Note: You can also define up to 8 speed dials without using line keys [see end of message]
Define a SD on a line key as follows:
Phone’s web-ui > Phone tab > Line Key N:
Extension: Disabled Short Name: SDTest
Share Call Appearance: private
Extended Function: fnc=sd;sub=812144735876@$PROXY;ext=812144735876@$PROXY
Where:
fnc—function
sd—speed dial
sub—tag to assign the SUBSCRIBE URL
812144735876:
8—steering digit
1—long distance
214—area code
4735876—DID
$PROXY—$PROXY [literally type this in]
ext—extension to dial [DID with steering digit in this case (strictly speaking, extension of phone being monitored)]
Use this speed dial by pressing the associated line key.
The release note syntax: fnc=type;sub=stationname@$PROXY;ext=extension#@$PROXYvid=#
Where: vid=#—specifies the extension the sidecar key is associated with. By default, it is Ext 1.
For example, if you have a registered Ext 2 with another proxy server, and you want to monitor other lines from that new account, you'll need to add "vid=2". When Ext 2 registers, the SUBSCRIBE message is then sent.
Assign up to 8 regular speed dials without using Line Keys:
Phone’s web-ui > User tab > Speed Dial > Speed Dial N: 812144735876
Where:
N—speed dial 2 through 9
812144735876:
8—steering digit
1—long distance
214—area code
4735876—DID
Use a regular speed dial by pressing the number, example “2” and then pressing the Dial soft key on the phone.
<end>
