we have CBS350-24P-4G fiber port not coming upNAME: "GigabitEthernet25" DESCR: "SFP-100Base-LX"PID: SFP-100-LX VID: Information Unavailable SN: 9802222809DataSwitch1F#sh fiber-ports optical-transceiver interface gi25Port Temp Voltage Current Output I...
Good Day Everyone,I have 4 brand new SAP 303 phones. Two of them worked fine. The other two get stuck in the "Initializing Network" stage and do not get an IP adress. I used the same port to provision the otehr phone so it isnt that. I have already t...
hi, by mistake i wrote the UDI product and serial number the same by mistake i need your helo to change the UDI product PID SN UDI-----------------------------------------------------------------...
Hi Cisco Team, Our Customer in indonesia have cisco devices installed in Singapore Site. Those devices using 8x5 nbd smartnet. Our question are: 1. If there is hardware failure the RMA part will be deliver dorect to singapore or to indonesia first? 2...
Hi, I tried to connect to OOB port for management, but I can't connect to it. The port not answer to ping too.I can connect to console port using serial cable.The port OOB seems well configured.
I am trying to add an AIR-AP2802I-E-K9 to a site in cisco business but can't due to PID being invalid when trying.Is the model not supported or am I missing something?
Hello Community, I'm writing to let you know that there is a critical POE defect in the CBS350 switches and you should avoid them if you require stable POE operations. This apparent software defect causes POE ports to randomly fault after 8 to 12 hou...
Hey,I simply cannot change a password on the CBS250-8T-D in my lab. No matter what password I try (I tried a bunch ranging between 10 and 14 characters), I'm always gettingPassword rejected - Passwords must not match words in the dictionary, and mus...
So the Cisco Small Business RV340, RV345, RV 160, RV260, RV345P, RV340W, RV260W, RV260P and RV160W VPN Router has all reached EOS & EOL. That's every small business router that Cisco currently has. Per Cisco, there is currently no product migration...
HelloI have two SG350-10 switches, that I want to set as DHCP servers for a local control network. I followed instructions, and it worked fine, until the server had to reboot. As soon as it was back online I noticed several issues :The devices can't ...
Hi. I need your help with this AP, because i can't access to AP using putty, when i try login in AP, Putty show me a differentes characters in console. The AP obtain a ip for DHCP but I can't enter either. Can you help me please?
I'm a bit behind in firmware versions on my CBS250 - I'm currently running 3.1.1.7Can I upgrade directly to the latest (3.4.0.17) or do I need to do some intermediate upgrade steps?
