Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
Configuring LACP to work between Catalyst and 300 Series switches by CLI.docx
4467
Configure Link Aggregation wieh LACP enabled between Catalyst and 300 Serires switches. Version 2.0 correct some typos, and Add PAgP as Cisco proprietary statement.
Beginner
Sx300/500 Inter-connect with Catalyst
LAG/LACP example
[Catalyst]
Interface rang f0/11 -12
Channel-protocol lacp
Channel-group 1 mode active
[Sx300/500]
SG300(config-if-range)#channel-group 1 mode
  on                   Add port without LACP
  auto                 Add port with LACP
SG300(config)#Port-Channel load-balance
  src-dst-mac-ip       Port channel load balancing is based on source and destination of MAC and IP addresses.
  src-dst-mac          Port channel load balancing is based on source and destination MAC address. [Default]
[Sx300/500]
SG300#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - VoIP Phone
                  M - Remotely-Managed Device, C - CAST Phone Port,
                  W - Two-Port MAC Relay
    Device ID       Local      Adv  Time To Capability   Platform     Port ID                    Interface  Ver. Live
       SW3             gi7      2     168     R S I    cisco WS-C3560-12P C-S       FastEthernet0/12
       SW3             gi8      2     168     R S I    cisco WS-C3560-12P C-S       FastEthernet0/11
SG300(config-if-range)#do sh int po 1
Load balancing: src-dst-mac.
Gathering information...
Channel  Ports
Po1      Active: gi7-8
SG300#show lacp Port-Channel 1
Port-Channel Po1
       Port Type Gigabit Ethernet
       Attached Lag id:
       Actor
               System Priority:32769
               MAC Address:    64:d8:14:5d:14:13
               Admin Key:      1000
               Oper Key:       1000
       Partner
               System Priority:32768
               MAC Address:    00:23:ac:c0:ac:00
               Oper Key:       1
SG300#show lacp gi 7
gi7 LACP parameters:
      Actor
              system priority:       32769
              system mac addr:       64:d8:14:5d:14:13
              port Admin key:        1000
              port Oper key:         1000
              port Oper number:      55
              port Admin priority:   1
              port Oper priority:    1
              port Admin timeout:    LONG
              port Oper timeout:     LONG
              LACP Activity:         ACTIVE
              Aggregation:           AGGREGATABLE
              synchronization:       TRUE
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
      Partner
              system priority:       32768
              system mac addr:       00:23:ac:c0:ac:00
              port Admin key:        0
              port Oper key:         1
              port Oper number:      269
              port Admin priority:   0
              port Oper priority:    32768
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
gi7 LACP statistics:
      LACP Pdus sent:                242
      LACP Pdus received:            217
gi7 LACP Protocol State:
      LACP State Machines:
              Receive FSM:           Current State
              Mux FSM:               Collecting Distributing State
              Periodic Tx FSM:       Slow Periodic State
      Control Variables:
              BEGIN:                 FALSE
              LACP_Enabled:          TRUE
              Ready_N:               FALSE
              Selected:              SELECTED
              Port_moved:            FALSE
              NNT:                   FALSE
              Port_enabled:          TRUE
      Timer counters:
              periodic tx timer:     26
              current while timer:   88
              wait while timer:      0
SG300#show lacp gi 8
gi8 LACP parameters:
      Actor
              port Oper key:         1000
              port Oper number:      56
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
      Partner
              port Admin key:        0
              port Oper key:         1
              port Oper number:      268
              collecting:            TRUE
              distributing:          TRUE
              expired:               FALSE
gi8 LACP statistics:
      LACP Pdus sent:                204
      LACP Pdus received:            188
gi8 LACP Protocol State:
      Control Variables:
              BEGIN:                 FALSE
              LACP_Enabled:          TRUE
              Ready_N:               FALSE
              Selected:              SELECTED
              Port_moved:            FALSE
              NNT:                   FALSE
              Port_enabled:          TRUE
      Timer counters:
              periodic tx timer:     14
              current while timer:   75
              wait while timer:      0
[Catalyst]
SW3(config-if)#do sh ether 1 sum
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Fa0/11(P)   Fa0/12(P)
SW3(config-if)#do sh ether 1 de
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
Minimum Links: 0
                Ports in the group:
Port: Fa0/11
Port state    = Up Mstr Assoc In-Bndl
Channel group = 1           Mode = Active          Gcchange = -
Port-channel  = Po1         GC   =   -             Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Fa0/11    SA      bndl      32768         0x1       0x1     0x10C       0x3D
Partner's information:
Port      Flags   Priority  Dev ID          Age    key    Key    Number  State
Fa0/11    SA      1         64d8.145d.1413   9s    0x0    0x3E8  0x38    0x3D
Age of the port in the current state: 0d:00h:09m:07s
Port: Fa0/12
Local information:
Fa0/12    SA      bndl      32768         0x1       0x1     0x10D       0x3D
Fa0/12    SA      1         64d8.145d.1413   9s    0x0    0x3E8  0x37    0x3D
Age of the port in the current state: 0d:00h:09m:05s
                Port-channels in the group:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 0d:00h:09m:47s
Logical slot/port   = 2/1          Number of ports = 2
HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =   LACP
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Fa0/11   Active             0
  0     00     Fa0/12   Active             0
Time since last port bundled:    0d:00h:09m:05s    Fa0/12
Time since last port Un-bundled: 0d:00h:09m:47s    Fa0/12
SW3(config-if)#do sh lacp 1 nei
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 1 neighbors
Fa0/11    SA      1         64d8.145d.1413  10s    0x0    0x3E8  0x38    0x3D
Fa0/12    SA      1         64d8.145d.1413  10s    0x0    0x3E8  0x37    0x3D
SW3(config-if)#do sh lacp 1 nei de
          Partner               Partner                     Partner
Port      System ID             Port Number     Age         Flags
Fa0/11    32769,64d8.145d.1413  0x38             15s        SA
          LACP Partner         Partner         Partner
          Port Priority        Oper Key        Port State
          1                    0x3E8           0x3D
          Port State Flags Decode:
          Activity:   Timeout:   Aggregation:   Synchronization:
          Active      Long       Yes            Yes
          Collecting:   Distributing:   Defaulted:   Expired:
          Yes           Yes             No           No
Fa0/12    32769,64d8.145d.1413  0x37             15s        SA
          1                    0x3E8           0x3D
          Active      Long       Yes            Yes
          Yes           Yes             No           No
GREAT
