Patrick Born
Specific ring tones can be configured in one of two ways:
1.       Directly on the phone:
a.       Dir/Directory soft key
b.      New Entry
c.       Insert Name, Number, and Select Ring, Default, by default
2.       Using the phone’s web-ui:
a.       http://<IP_of_phone>/pdir.htm
Example: For an entry that will display the following on the phone and cause the Classic-4 ring tone to play when the 2145551212 phone calls:
Sally
2145551212
Insert the following next to the first vacant Personal Directory number: Syntax is:
n=Sally;p=2145551212;r=4
Where:
n—name for listing
p=incoming phone number that will cause the special ring
r—identifies the ring tone as listed http://<IP_of_phone>/admin/advanced > Ring Tone > RingN:
Note that:
“0” in this syntax enables a silent ring. The phone’s LEDs will flash, but the phone will not ring
Ring4: n=Classic-4;w=3;c=4 is called “4” in this syntax
Ring9: n=Simple-5;w=2;c=5 is called “9” in this syntax
Ring10: n=Office;w=4;c=1 is called “10” in this syntax
<end>
