Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
CUCC Page Content Changes
301
No.PriorityStatusDescriptionSubmit DateReported ByDetail
13closedremove extra spaces 02/24/2014Patrick
see #1 in doc
23closedremove extra spaces 02/24/2014Patrick
see #2 in doc
33closedmove before you begin box02/24/2014Patrick
see #3 in doc
43closedchange heading 02/24/2014Patrick
see #4 in doc
53closedremove option to add remark02/24/2014Patrick
see #5 in doc
63closedchange site-to-site description02/24/2014Patrick
see #6 in doc
73closedhelp not updating when user mouses over headings02/24/2014Patrick
see #7 in doc
83closedchange context sensitive help02/24/2014Patrick
see #8 in doc
93closedchange context sensitive help02/24/2014Patrick
see #9 in doc
103closedchange context sensitive help02/24/2014Patrick
see #10 in doc
113closedchange context sensitive help02/24/2014Patrick
see #11 in doc
123closedchange terms of use02/24/2014Patrick
see #12 in doc
133closedadd space02/24/2014Patrick
see #13 in doc
143Openremove "Make a Wish" button02/24/2014Patrick
see #14 in doc [Navin wants this button]
153closedchange behavior of OK button02/24/2014Patrick
see #15 in doc
163Openchange title02/24/2014Patrick
see #16 in doc
173Open
Change from Smart Business Configurator to:
"Cisco Unified Configurator"
02/24/2014Patrick
see #17 in doc
183Open
Global change throughout all pages.
Change from: SBCC
Change to: CUCC
02/24/2014Patrick
see #18 in doc
193closed
Change to:
Supports: Cisco Unified Communications Manager
02/24/2014Patrick
see #19 in doc
203closed
change to [note position of spaces]:
10.0, 9.1, and 9.0
02/24/2014Patrick
see #20 in doc
213closed
change to:
To send feedback for this tool, email:
02/24/2014Patrick
see #21 in doc
223closed
Change from:
"... Unified Communications Manager and CUxN using ..."
Change to:
"... Cisco Unified Communications Manager (CUCM) and Cisco Unity Connection (CUxN) using ..."
02/24/2014Patrick
see #22 in doc
233closed
change from: "c"
change to: "©"
02/24/2014Patrick
see #23 in doc
243closed
Change from "This section ... ... for the phones"
Change to: "Use this tool to enable Extension Mobility, update the Home Device Pool, and the default Calling Search Space for phones."
02/25/2014Patrick
see #24 in doc
253closed
change from: "... phones that will be enabled."
change to: "... phones that can be configured."
02/25/2014Patrick
see #25 in doc
263closed
Add context sensitive help for Remove Device button: "Click Remove Device to remove selected device or devices from the list to be configured."
02/25/2014Patrick
see #26 in doc
273OpenRemove Attention pop-up02/27/2014Patrick
see #27 in doc
28a3OpenEnable both IP address or name as input02/27/2014Patrick
see #28a in doc
28b3OpenChange context sensitive Help as follows: “Enter the name or IP address of the Unified CM Publisher. If your system uses IP addresses, then you must use the IP address, if the system uses a name, then you must use the name. Example IP address: 10.89.76.110 Example name: cucmBE6000"02/27/2014Patrick
see #28b in doc
293OpenChange Title
    Modify Define Unified Communications Server
Change to:
   “Modify Unified Communications Server’s Definition”
02/27/2014Patrick
see #29 in doc
303OpenDisplay file browser instead of freeform text box for "Continue Saved Session from"02/27/2014Patrick
see #30 in doc
313OpenUC Base Configuration Template is selectable on two consecutive pages, should only be on one page.02/27/2014Patrick
see #31 in doc
323Openadd a space after ) and before such03/07/2014Patrick
see #32 in doc
333Openadd a space after . and before The03/07/2014Patrick
see #33 in doc
343Openremove new from title03/07/2014Patrick
see #34 in doc
353Open
change from Ldap to LDAP
03/07/2014Patrick
see #35 in doc
363Open
change "w/ DN" to "with DN"
03/07/2014Patrick
see #36 in doc
373Open
change from “This wizard will guid you set Self-Provisioning parameter” to:
“Configure Self-Provisioning parameters”
03/07/2014Patrick
see #37 in doc
383Openchange to:
"... tool, please ..."
[insert space after tool, before please]
03/07/2014Patrick
see #38 in doc
393Openchange to:
03/07/2014Patrick
see #39 in doc
403Open
change pop-up text to: “
Applying this configuration will overwrite any existing configuration. Continue?
03/07/2014Patrick
see #40 in doc
413Open
change pop-up button to "Yes"
03/07/2014Patrick
see #40 in doc
423Open
change pop-up button to "No"
03/07/2014Patrick
see #40 in doc
433Open
03/07/2014Patrick
see #43 in doc
443Open
change from "New ... ... Configuration Phase"
to:
"Activity log"
03/07/2014Patrick
see #44 in doc
453Open
change from "on cluster" to
"... on a cluster ..."
03/07/2014Patrick
see #45 in doc
463Open
change from "Server'  s Definition" to
"... Server's Definition ..."
03/07/2014Patrick
see #46 in doc
473Open
change from "... relationships.A null ..."
to:
"... relationships. A null ..."
03/07/2014Patrick
see #47 in doc
483Open
Applying this configuration will overwrite any existing configuration. Continue?”
03/07/2014Patrick
see #48 in doc
493Open
03/07/2014Patrick
see #48 in doc
503Open
03/07/2014Patrick
see #48 in doc
513Open
Replace sentence with:
"Configure CUCM-supported endpoints."
03/07/2014Patrick
see #51 in doc
523Open
Replace sentence with: "Select the endpoint template file."
03/07/2014Patrick
see #52 in doc
533Open
03/07/2014Patrick
see #53 in doc
543Open
03/07/2014Patrick
see #53 in doc
