Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Forward Calls on a Cisco IP Phone 8800 Series Multiplatform Phone
1404
Objective
Forwarding calls on the Cisco IP Phone allows you to set another line or phone number where calls will be forwarded when it is not possible to answer the call from that specific line. You can set call forwarding to all calls, or in special situations such as if the line is busy or if there is no answer.
This article aims to show you how to forward calls on the Cisco IP Phone 7800 or 8800 Series Multiplatform Phone.
Applicable Devices
  • 8800 Series
Software Version
  • 11.0.1
Forward Calls
Through the Web-based Utility
Forward All Calls
Step 1. Log in to the web-based utility of the IP phone and click Admin Login > advanced.
Step 2. Click Voice > User.
Step 3. Under Call Forward area, choose Yes from the Cfwd Setting drop-down menu.
Step 4. (Optional) If you wish to forward all incoming calls, enter the phone number where all calls will be forwarded in the Cfwd All Dest field.
Note: In this example, all calls will be forwarded to 705.
Forward Calls in Special Situations
Step 1. (Optional) If you wish to forward calls only if the line is busy, enter the phone number where the calls will be forwarded in the Cfwd Busy Dest field.
Note: In this example, calls will be forwarded to 705 in case the line is busy.
Step 2. (Optional) If you wish to forward calls only if not answered, enter the phone number where the calls will be forwarded in the Cfwd No Ans Dest field.
Note: In this example, calls will be forwarded to 705 if unanswered.
Step 3. In the Cfwd No Ans Delay field, enter the number of seconds that the call should remain unanswered before it will be forwarded to the number.
Note: In this example, the call will be forwarded after 20 seconds if not answered.
Step 4. Click Submit All Changes.
You should now have successfully configured Call Forwarding on your Cisco IP Phone through the web-based utility.
Through the Phone GUI
Forward All Calls
Step 1. On your IP Phone, navigate to the line where you want to enable call forwarding and then press the Forward softkey.
Note: In this example, the line used is 8861.
Step 2. Dial the number where you want to forward all incoming calls and then press the Call softkey.
Note: In this example, all incoming calls for line 8861 will be forwarded to 705.
Step 3. Check the screen for the indication that all calls will be forwarded to the number you have set. The screen should display the phone number with a forwarding sign on it.
Step 4. (Optional) If you wish to disable Call Forwarding to the specified line, press the Clr fwd softkey.
You should now have successfully enabled all calls forwarding on your Cisco IP Phone 7800 or 8800 Series Multiplatform Phone.
Step 1. Press the Applications button on the IP Phone.
Step 2. Using the Navigation cluster button, navigate to User preferences then press the Select softkey.
Step 3. Choose Call preferences then press the Select softkey.
Step 4. Press the Navigation cluster right button to set Call forwarding to On.
Step 5. (Optional) If you wish to forward all incoming calls regardless of the situation, enter the phone number where all calls will be forwarded in the Forward all number field.
Step 6. (Optional) If you wish to forward calls only if the line is busy, enter the phone number where the calls will be forwarded in the Forward busynumber field.
Step 7. (Optional) If you wish to forward calls only if not answered, enter the phone number where the calls will be forwarded in the Fwd no answer number field.
Step 8. In the Fwd no answer delay field, enter the number of seconds that the call should remain unanswered before it will be forwarded to the number.
Step 9. Press the Set softkey.
When a call comes in and it has been completely forwarded, the screen on your IP Phone should go back to its standby mode with the forwarded call instance indicator beside the line called.
You should now have successfully configured call forwarding on your Cisco IP Phone 7800 or 8800 Series Multiplatform Phone.
