Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
Generating a sample configuration file for SPA Voice products
9985
You can use the SPC (SPA Profile Compiler) for each product to generate the sample configuration file in XML or text. The SPC (Windows version) is DOS command based, so when you type in the command, it will give you the option to generate the sample configuration file for the product (and the firmware version associated to the SPC). You can also use the Linux version to achieve same goal.
Procedure can be summarized as follows:
(1) Download the SPC for phones from Cisco
(2) Open the spc in the DOS command window, e.g. wrp400-1-00-02-spc-win32-i386
(3) Run the command to get the sample file
     For XML format: wrp400-1-00-02-spc-win-i386 --sample-xml output_filename.xml
     For text format (you need to compile it with SPC after modifications): wrp400-1-00-02-spc-win-i386 --sample-profile output_filename.txt
(4) Then, you can modify the text or xml file to contain the desired parameters' values
(5) If using text format, then you need to compile it again: wrp400-1-00-02-spc-win-i386 source_text_file target_binary_file.cfg
If you need further information on the parameters names or the provisioning mechanism, I suggest you check the Provisioning Guide and the related product Admin Guide (located in the documentation area of each product line).
Ask the Expert- Introduction to Network Design
